Epson Perfection V370 Flatbed Scanner
£143.35
Delivery:
Key features
  • 4,800dpi for superior quality
  • Scan slides, film and negatives
  • Scan bulky books and 3D objects
  • Scan to email or cloud storage
  • Saves power and money
Product codes
Epson ReadyScan LED technology delivers scans instantly with virtually no warm-up time, and is very power-efficient, helping to reduce your energy bills and impact on the environment.
Scanning bulky books or 3D objects is no problem, as the Perfection V370 Photo's lid has an extendable hinge than can open up to 180 degrees. Even if parts of the book or object being scanned are not in contact with the scanner's glass, they will still be in focus and captured accurately. This is because Epson's CCD image sensor technology offers a greater depth of field than the CIS (contact image censor) technology used in most comparable scanners.
Simple to use, the Perfection V370 Photo's enables you to conveniently scan to email at the touch of a button, or scan to multi-page, searchable PDF. Other useful photo and document editing features are available using the included software: Epson Easy Photo Fix makes it easy to bring your originals back to life by restoring faded colour, removing the appearance of dust and scratches and adjusting backlight; Optical Character Recognition (OCR) allows you to copy, paste and edit text from scanned documents; and Epson Document Capture enables direct scanning to cloud storage services, so you can access your scans from any computer or mobile device.
Product Description Epson Perfection V370 Photo - flatbed scanner - desktop - USB 2.0
Device Type Flatbed scanner - desktop
Interface Type USB 2.0
Scan Element Type CCD
Light Source LED
Max Supported Document Size A4 (210 x 297 mm)
Input Type Colour
Grayscale / Color Depth 48-bit colour
Grayscale / Color Depth (External) 48-bit colour
Optical Resolution 4800 dpi x 9600 dpi
Max Document Size 210 mm x 297 mm
Supported Document Type Plain paper, bulk objects (such as books, magazines and other bound materials), photo
Document Feeder Type Manual
Power AC 230V (50 - 60 Hz)
System Requirements Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.3 or later, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions)
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 28 cm x 43 cm x 4.1 cm
Weight 2.2 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson Perfection V370...
£143.35
