Scan all your prints, negatives and slides quickly and efficiently. Complete with film holders it handles just about any size and format, including 35 mm filmstrips, mounted slides and full panoramic medium format film.
Advanced DIGITAL ICE technologies make it easy to remove dust and scratches from film and photos, and you can check every detail in your images with the resizable preview window.
Featuring Epson ReadyScan LED technology, you can start scanning instantly with no warm-up time. You also use less energy when you scan, which is better for the environment and also saves you money.
And whatever you scan you can be sure of capturing every detail with high-quality 6400 dpi optical resolution with Epson Matrix CCD technology.
Product Description | Epson Perfection V600 Photo - flatbed scanner | Device Type | Flatbed scanner - desktop | Interface Type | USB 2.0 | Scan Element Type | CCD | Light Source | White LED | Max Supported Document Size | 216 x 297 mm | Input Type | Colour | Grayscale / Color Depth | 16-bit (64K grey levels) / 48-bit colour | Grayscale / Color Depth (External) | 16-bit (64K grey levels) / 48-bit colour | Optical Resolution | 6400 dpi x 9600 dpi | Interpolated Resolution | 12800 dpi x 12800 dpi | Max Document Size | 216 mm x 297 mm | Supported Document Type | Transparencies, plain paper, slides, bulk objects (such as books), film | Document Feeder Type | Manual, automatic (optional) | Power | AC 120/230 V ( 50/60 Hz ) | Microsoft Certification | Compatible with Windows 7 | Dimensions (WxDxH) | 28 cm x 48.5 cm x 11.8 cm | Weight | 4 kg | Manufacturer Warranty | 1 year warranty |
General | |
Scanner | |
Grayscale Depth | 16-bit (64K grey levels) |
Grayscale Depth (External) | 16-bit (64K grey levels) |
Colour Depth | 48-bit colour |
Colour Depth (External) | 48-bit colour |
Bulb / Light Source Type | White LED |
Scan Density Range | 3.4D |
Control Panel Buttons Functions | Copy, start, Scan-to-Email, Scan-to-PDF |
Scanner Features | Digital ICE Technology, EPSON ReadyScan LED Technology |
Media Handling | |
Supported Document Size Details | Flatbed - up to 216 x 297 mm , Film - up to film 135 (35mm) - 12 frames (strip) , Slide - up to film 135 (35mm) - 4 frames (mounted) |
Expansion / Connectivity | |
Interfaces | USB 2.0 - Type B |
Miscellaneous | |
Included Accessories | Film adaptor, slide holder |
Cables Included | 1 x USB cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V ( 50/60 Hz ) |
Power Consumption Operational ( Standby ) | 16.5 Watt ( 1.6 Watt ) |
Software / System Requirements | |
Software Included | ASF Digital ICE, ABBYY FineReader 5.0 Sprint Plus, Epson Scan 3.8, ABBYY FineReader 6.0 Sprint Plus, EPSON Event Manager, EPSON Copy Utility |
Dimensions & Weight | |
Width | 28 cm |
Depth | 48.5 cm |
Height | 11.8 cm |
Weight | 4 kg |
Manufacturer Warranty | |
Service & Support | 1 year warranty |
Service & Support Details | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% |
