Epson Perfection V600 A4 colour flatbed scanner
£262.45
29 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High-quality 6400 dpi film and photo scanner
  • Restore film and photos with DIGITAL ICE technologies
  • Make quick scans and save energy with Epson ReadyScan LED technology
  • Scan a wide range of photo and film formats
  • Convenient resizable preview window
  • Scan to multi-page searchable PDF
  • Type: Flatbed scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 297 mm
  • Interface: USB 2.0
  • Compatibility: Mac, PC
Product codes
Scan all your prints, negatives and slides quickly and efficiently. Complete with film holders it handles just about any size and format, including 35 mm filmstrips, mounted slides and full panoramic medium format film.
Advanced DIGITAL ICE technologies make it easy to remove dust and scratches from film and photos, and you can check every detail in your images with the resizable preview window.
Featuring Epson ReadyScan LED technology, you can start scanning instantly with no warm-up time. You also use less energy when you scan, which is better for the environment and also saves you money.
And whatever you scan you can be sure of capturing every detail with high-quality 6400 dpi optical resolution with Epson Matrix CCD technology.
Product Description Epson Perfection V600 Photo - flatbed scanner
Device Type Flatbed scanner - desktop
Interface Type USB 2.0
Scan Element Type CCD
Light Source White LED
Max Supported Document Size 216 x 297 mm
Input Type Colour
Grayscale / Color Depth 16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External) 16-bit (64K grey levels) / 48-bit colour
Optical Resolution 6400 dpi x 9600 dpi
Interpolated Resolution 12800 dpi x 12800 dpi
Max Document Size 216 mm x 297 mm
Supported Document Type Transparencies, plain paper, slides, bulk objects (such as books), film
Document Feeder Type Manual, automatic (optional)
Power AC 120/230 V ( 50/60 Hz )
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 28 cm x 48.5 cm x 11.8 cm
Weight 4 kg
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson Perfection V600...
£262.45
