Print your own labels
With the ColorWorks C3500 (TM-C3500), you can easily customise and print your own colour labels. Whether it's printing packaging labels with colourful logos and pictures or tickets and ID cards with important barcodes and product information, this printer ensures you can print it all from one machine. It also helps you conform with GHS international chemical labelling guidelines, as labels can be printed on-demand without using pre-printed templates.
High-quality and durable
Thanks to the individual pigment ink cartridges, you can create fast-drying, highly detailed labels that are smudge, water and fade resistant. Not only will your labels look great, but the pigment ink's long-lasting, durable qualities make it perfect for a wide variety of environments.
Easy-to-use 4-colour label printer
You can easily print on a wide selection of materials, including matte and glossy coated paper and filmic labels. This means you can create exactly the type of labels you need. The LCD screen displays ink levels and printer status information, while front operation and easy setup software means you can operate the printer without specialist training.
Saving you money
Thanks to individual pigment ink cartridges, this label printer is ideal for cutting printing costs with its low cost-per-label, as you only need to replace the colour used.
Product Description | Epson TM C3500 - label printer - colour - ink-jet | Printer Type | Label printer - ink-jet - colour | Weight | 12 kg | Inkjet Technology | Epson Micro Piezo | Ink Palette Supported (Colours) | 4-ink - cyan, magenta, yellow, black | Max Media Size | Continuous paper 30 mm - 112 mm (width) | Min Media Size (Custom) | 30 mm | Max Media Size (Custom) | 112 mm | Print Speed | Up to 103 mm/sec | Max Resolution (B&W) | 720 x 360 dpi | Cutter | Yes | Interface | LAN, USB host | Media Type | Labels, continuous paper labels, die cut labels | Features | Black Mark sensor | Networking | Print server | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 31 cm x 28.3 cm x 26.1 cm |
General | |
Printer | |
Nozzle Configuration | 4 x 360 nozzles (black, cyan, magenta, yellow) |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Type | Epson DURABrite Ultra inks |
Print Speed | Up to 103 mm/sec - 360x360 dpi |
Built-in Devices | Status LCD |
Connectivity Technology | Wired |
Auto Cutter | Yes |
Media Handling | |
Max Printing Width | 104 mm |
Roll Maximum Outer Diameter | 101.6 mm |
Networking | |
Expansion / Connectivity | |
Connections | 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x ink cartridge (black) , 1 x ink cartridge (yellow) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink maintenance kit |
Media Included | Roll of media |
MTBF | 88,000 hour(s) |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Device | Power adapter - external |
Frequency Required | 50 - 60 Hz |
Power Consumption Operational | 30 Watt |
Power Consumption Stand by | 3 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - carry-in |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Dimensions & Weight | |
Width | 31 cm |
Depth | 28.3 cm |
Height | 26.1 cm |
Weight | 12 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 44 cm |
Depth (Shipping) | 40 cm |
Height (Shipping) | 42.5 cm |
Weight (Shipping) | 15.04 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
