Epson TM-C3500 Colour Ink-Jet Label Printer
£1,423.28
Delivery:
Standard: 1-3 working days
Key features
  • Long-lasting pigment ink
  • Print labels at up to 103mm/sec
  • Print on a wide variety of media
  • LCD screen for ink and printer status
  • Individual ink cartridges
  • Type: Printer
  • Functionality: Printer
  • Output Type: Colour
  • Wireless Capability: Wired
  • Technology: Ink-jet
Product codes
Print your own labels
With the ColorWorks C3500 (TM-C3500), you can easily customise and print your own colour labels. Whether it's printing packaging labels with colourful logos and pictures or tickets and ID cards with important barcodes and product information, this printer ensures you can print it all from one machine. It also helps you conform with GHS international chemical labelling guidelines, as labels can be printed on-demand without using pre-printed templates.
High-quality and durable
Thanks to the individual pigment ink cartridges, you can create fast-drying, highly detailed labels that are smudge, water and fade resistant. Not only will your labels look great, but the pigment ink's long-lasting, durable qualities make it perfect for a wide variety of environments.
Easy-to-use 4-colour label printer
You can easily print on a wide selection of materials, including matte and glossy coated paper and filmic labels. This means you can create exactly the type of labels you need. The LCD screen displays ink levels and printer status information, while front operation and easy setup software means you can operate the printer without specialist training.
Saving you money
Thanks to individual pigment ink cartridges, this label printer is ideal for cutting printing costs with its low cost-per-label, as you only need to replace the colour used.
Product Description Epson TM C3500 - label printer - colour - ink-jet
Printer Type Label printer - ink-jet - colour
Weight 12 kg
Inkjet Technology Epson Micro Piezo
Ink Palette Supported (Colours) 4-ink - cyan, magenta, yellow, black
Max Media Size Continuous paper 30 mm - 112 mm (width)
Min Media Size (Custom) 30 mm
Max Media Size (Custom) 112 mm
Print Speed Up to 103 mm/sec
Max Resolution (B&W) 720 x 360 dpi
Interface LAN, USB host
Media Type Labels, continuous paper labels, die cut labels
Features Black Mark sensor
Networking Print server
Power AC 120/230 V
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 31 cm x 28.3 cm x 26.1 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson TM-C3500 Colour...
£1,423.28
