Epson TM-L90 -412 S01 BUILT-IN USB
£408.74
Delivery:
Key features
  • Ideal for label and barcode printing
  • Thermal printing up to 150mm/sec
  • Mounts horizontally, vertically or with a wall bracket
  • Drop in paper loading and built-in-USB interface
  • Label and receipt paper, from 38mm to 80mm wide
  • Type: Printer
  • Functionality: Printer
  • Output Type: Monochrome
  • Wireless Capability: Wired
  • Technology: Thermal line
Product codes
Label and barcode printing
With fast, thermal printing of up to 150mm/sec, the TM-L90 is a valuable asset to your business. With this model, you'll be able to print out and get on with more important work, rather than waiting around for labels or barcodes.
More connectivity
This printer benefits from high speed serial, Ethernet and parallel connectivity plus a built-in USB interface, which means it can be operated as a network device.
Easy to use
The small footprint and wall bracket mean that you can place it almost anywhere, in any position, for convenient and versatile printing. Practical design features, such as drop-in paper load, selectable auto-cutter and jamproof paper feeding, ensure smooth operation. The easy-to-use operator cover and lifespan of up to 20 million lines enable long-lasting, trouble-free maintenance.
High quality labels
Its greyscale capabilities allow highly customised layouts, and logos and promotional messages can be added with ease.
Larger receipt rolls, wider paper
Altogether, the TM-L90 label printer is one of the most efficient label printers available: it accepts large paper rolls (up to 90mm in diameter) and you can select paper widths between 38 and 80mm to produce labels in different sizes.
Product Description Epson TM L90 - receipt printer - monochrome - thermal line
Printer Type Receipt printer - thermal line - monochrome
Weight 1.9 kg
Max Media Size Roll (8 cm)
Max Media Size (Custom) 80 mm
Print Speed Up to 150 mm/sec - max speed
Max Resolution (B&W) 203 dpi
Interface USB 2.0, serial
RAM Installed (Max) 4 KB
Media Type Labels, receipt paper
Microsoft Certification Compatible with Windows 7
Enclosure Colour Dark grey
Dimensions (WxDxH) 14 cm x 14.8 cm x 20.3 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson TM-L90 -412 S01...
£408.74
