Epson TM-T20II (002A0) Built in USB + serial ,PS, Receipt pri...
Epson TM-T20II (002A0) Built in USB + serial ,PS, Receipt printer
Key features
  • Automatic paper reduction function
  • Mechanism life of 15 million lines
  • Print speed of 200mm/sec
  • Two models: 1) USB + Serial 2) USB + Ethernet
Product codes
Affordable
This easy-to-use model is our most affordable POS receipt printer and has an 80mm printing width. Its Automatic Paper Reduction feature reduces top and bottom margins, line feed width and bar code height, allowing for flexible receipt printing. This monitors and controls the amount of paper used. Paper costs are minimised by printing the top logo of the next receipt before cutting, so the top margin is further reduced by 12mm.
Reliable
With its MTBF of 360,000 hours and a mechanism life of 15 million lines, you can rely on the TM-T20II in high-volume printing environments.
Flexible
The TM-T20II comes with a built-in USB interface and you can select from two models: 1) USB + Serial, 2) USB + Ethernet, making the model a long-term investment as it is possible to switch connectivity at any time.
Fast
Its print speeds of 200mm/sec can save you time and its competitive price and running costs can save you money, ideal for when you need to beat queues quickly.
Product Description Epson TM T20II - receipt printer - monochrome - thermal line
Printer Type Receipt printer - thermal line - monochrome
Weight 1.7 kg
Localisation United Kingdom
Max Media Size Roll (8 cm)
Max Media Size (Custom) 80 mm
Print Speed Up to 200 mm/sec - max speed
Max Resolution (B&W) 203 x 203 dpi
Interface USB 2.0, serial
Media Type Receipt paper
Enclosure Colour Dark grey
Dimensions (WxDxH) 14 cm x 19.9 cm x 14.6 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson TM-T20II (002A0)...
