Epson WorkForce DS-310 Duplex A4 Document Scanner
£192.26
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Manage paperwork quickly and effectively while on the move
  • Easy to carry or store in a drawer
  • Single and double-sided scanning at 300dpi in colour or monochrome
  • 20-page automatic document feeder
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: A4 (210 x 297 mm)
  • Interface: USB 3.0
  • Compatibility: Mac, PC
Product codes
It's easy to scan and manage your paperwork on the go with the DS-310. Its compact and lightweight design means that it's ideal for carrying in a bag or even storing in a drawer. Give yourself the flexibility to scan what you need, when you need it. With the DS-310, you can capture documents at 300dpi in color and monochrome with absolute ease. When it comes to media, it's almost limitless with both single and double-sided scanning, and the ability to handle card and paper between 52 and 230gsm.
Product Description Epson WorkForce DS-310 - document scanner - desktop - USB 3.0
Device Type Document scanner - desktop
Interface Type USB 3.0
Additional Functions Scan to print, scan to FTP, scan to folder, scan to SharePoint
Max Supported Document Size A4 (210 x 297 mm)
Input Type Colour
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 25 ppm (mono) / 25 ppm (colour)
Max Document Size 215.9 mm x 1117.6 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, business card, plastic card, envelope, post card
Document Feeder Type Automatic
Document Storage Capacity 20 sheets
Duty Cycle 500 scans per day
Power AC 100/120/230 V (50 - 60 Hz)
System Requirements Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x
Dimensions (WxDxH) 28.8 cm x 8.9 cm x 5.1 cm
Weight 1.1 kg
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson WorkForce DS-310...
£192.26
