It's easy to scan anywhere with the fastest portable business scanner on the market, thanks to a built-in battery and wireless connectivity
Product Description | Epson WorkForce DS-360W - document scanner - desktop - USB 3.0, Wi-Fi(n) | Device Type | Document scanner - desktop | Interface Type | USB 3.0, Wi-Fi(n) | Additional Functions | Email, scan to print, scan to network share, scan to FTP, scan to folder, scan to SharePoint | Max Supported Document Size | A4 (210 x 297 mm) | Input Type | Colour | Optical Resolution | 1200 dpi x 1200 dpi | Max Document Scan Speed | 25 ppm (mono) / 25 ppm (colour) | Max Document Size | 215.9 mm x 1117.6 mm | Automatic Duplexing | Yes | Supported Document Type | Plain paper | Document Feeder Type | Automatic | Document Storage Capacity | 20 sheets | Duty Cycle | 500 scans per day | Power | AC 100 - 240 V (50/60 Hz) | System Requirements | Microsoft Windows XP, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x | Dimensions (WxDxH) | 28.8 cm x 8.9 cm x 6.7 cm | Weight | 1.3 kg | Manufacturer Warranty | 1-year warranty |
General | |
Scanner | |
Scan Mode | Single-pass |
Max Document Scan Speed B/W | 25 ppm |
Max Document Scan Speed Colour | 25 ppm |
Scanner Speed Details | 25 ppm - black & white - 300 dpi , 25 ppm - colour - 300 dpi |
Scan File Formats | BMP, JPEG, TIFF, PDF |
Compliant Standards | TWAIN |
Media Handling | |
Supported Document Size Details | ADF - up to 215.9 x 1117.6 mm |
Expansion / Connectivity | |
Interfaces | USB 3.0 |
Miscellaneous | |
Cables Included | 1 x USB cable |
Power | |
Voltage Required | AC 100 - 240 V (50/60 Hz) |
Power Consumption Operational (Standby) | 8 Watt |
Power Consumption Stand by | 0.3 Watt |
Software / System Requirements | |
Software Included | Presto! BizCard, EPSON Document Capture Pro, EPSON Document Capture, EPSON Scan 2 |
OS Required | Microsoft Windows XP, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x |
Dimensions & Weight | |
Width | 28.8 cm |
Depth | 8.9 cm |
Height | 6.7 cm |
Weight | 1.3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 15 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
