It's easy to scan anywhere with the fastest portable business scanner on the market, thanks to a built-in battery and wireless connectivity
Product Description | Epson WorkForce DS-360W - document scanner - desktop - USB 3.0, Wi-Fi(n) | Device Type | Document scanner - desktop | Interface Type | USB 3.0, Wi-Fi(n) | Additional Functions | Email, scan to print, scan to network share, scan to FTP, scan to folder, scan to SharePoint | Max Supported Document Size | A4 (210 x 297 mm) | Input Type | Colour | Optical Resolution | 1200 dpi x 1200 dpi | Max Document Scan Speed | 25 ppm (mono) / 25 ppm (colour) | Max Document Size | 215.9 mm x 1117.6 mm | Automatic Duplexing | Yes | Supported Document Type | Plain paper | Document Feeder Type | Automatic | Document Storage Capacity | 20 sheets | Duty Cycle | 500 scans per day | Power | AC 100 - 240 V (50/60 Hz) | System Requirements | Microsoft Windows XP, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x, Microsoft Windows Server 2012 (64-bit) | Dimensions (WxDxH) | 28.8 cm x 8.9 cm x 6.7 cm | Weight | 1.3 kg | Manufacturer Warranty | 1-year warranty |
General | |
Scanner | |
Scan Mode | Single-pass |
Max Document Scan Speed B/W | 25 ppm |
Max Document Scan Speed Colour | 25 ppm |
Scanner Speed Details | 25 ppm - black & white - 300 dpi , 25 ppm - colour - 300 dpi |
Scan File Formats | BMP, JPEG, TIFF, PDF |
Compliant Standards | TWAIN |
Media Handling | |
Supported Document Size Details | ADF - up to 215.9 x 1117.6 mm |
Expansion / Connectivity | |
Interfaces | USB 3.0 |
Miscellaneous | |
Cables Included | 1 x USB cable |
Power | |
Voltage Required | AC 100 - 240 V (50/60 Hz) |
Power Consumption Operational (Standby) | 8 Watt |
Power Consumption Stand by | 0.3 Watt |
Software / System Requirements | |
Software Included | Presto! BizCard, EPSON Document Capture Pro, EPSON Document Capture, EPSON Scan 2 |
OS Required | Microsoft Windows XP, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x, Microsoft Windows Server 2012 (64-bit) |
Dimensions & Weight | |
Width | 28.8 cm |
Depth | 8.9 cm |
Height | 6.7 cm |
Weight | 1.3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 15 - 80% |
