This device is specially designed to accommodate documents individually, and is ideal for users with specific capture needs, such as scanning bound materials and thick or fragile documents. This scanner can be easily integrated into vertical applications thanks to TWAIN, ISIS and WIA support, as well as Document Capture Pro connectors.
High-quality scanning results are ensured by CCD technology and innovating imaging features, such as Book Spine Correction, and improved colour dropout/enhance powered by Epson Scan. In addition, Document Capture Pro makes it easy to treat scanned data before its conversion and distribution in virtually any document repository or document management system.
This scanner and its features can be shared between multiple users using the optional Network Interface Panel. Combined with Document Capture Pro solutions, the Network Interface Panel allows users to benefit from Push Scan features and customise ‘scan to’ job functions such as ‘scan to email’ or ‘scan to Microsoft SharePoint®’, among others*2. These features enable complicated tasks to be carried out effortlessly.
Epson ReadyScan LED technology eradicates warm-up time, guarantees an absence of mercury, and lowers power consumption. These elements, combined with ENERGY STAR qualification*1, creates an environmentally friendly device.
Product Description | Epson WorkForce DS-50000 - flatbed scanner - USB 2.0 | Device Type | Flatbed scanner | Interface Type | USB 2.0 | Max Supported Document Size | A3 (297 x 420 mm) | Input Type | Colour | Grayscale / Color Depth | 8-bit (256 colours) / 16-bit (64k colours) | Grayscale / Color Depth (External) | 24-bit (16.7 million colours) / 48-bit colour | Optical Resolution | 600 dpi x 600 dpi | Interpolated Resolution | 9600 dpi x 9600 dpi | Scan Speed | 4 sec / page | Supported Document Type | Plain paper | Document Feeder Type | Manual | Power | AC 120/230 V | System Requirements | Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6 | Microsoft Certification | Compatible with Windows 7 | Dimensions (WxDxH) | 64 cm x 46.8 cm x 15.6 cm | Weight | 14.8 kg | Environmental Standards | ENERGY STAR Qualified |
Customer return - item has been opened but is in excellent condition
Ref: 8FWM 041250 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
