Epson WorkForce DS-520N A4 Colour Networked Sheetfed Scanner
£496.90
Delivery:
Key features
  • Up to 30ppm / 60ipm
  • Document Capture Pro compatiblity
  • Advanced feed technology
  • Push Scan features with pre-defined job profiles
  • Quickly scan both sides of a document
Product codes
High-speed scanner
The DS-520N has a compact footprint and high-speed scanning of up to 30ppm / 60ipm, even at 300dpi in both color and monochrome. This, combined with hardware JPEG compression, makes large scan jobs faster to process. With the Network Interface Unit, it is ideal for sharing across office and department networks.
Document workflow
Epson Document Capture Pro software¹ makes it easy to integrate this business scanner into your document management system, speeding up workflow and enabling you to capture, convert and distribute scanned information into your document repositories. Benefit from Push Scanning with pre-defined job profiles. In addition, barcode recognition and Zonal OCR will help automate large document processes, such as file naming and folder creation. It's easy to integrate thanks to TWAIN, ISIS and WIA driver support.
Efficient
Epson 's scanning software offers a wide range of advanced document imaging features, including multi-document size detection, text enhancement and automatic de-skew to improve efficiency and increase productivity.
Network sharing}
Easily integrate this network-ready model into your company environment. Combined with Document Capture Pro/Pro Server¹, this scanner increases productivity with customisable PushScan functions from the scanner panel such as scan-to Microsoft SharePoint and cloud services.
Epson WorkForce DS-520N - document scanner - desktop - USB 2.0, Gigabit LAN
Document scanner - desktop
Interface Type
Light Source
LED
Additional Functions
Email, scan to network share, scan to FTP
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
216 mm x 914 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8
29.7 cm x 15.2 cm x 15.4 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson WorkForce DS-520...
£496.90
