Epson WorkForce DS-5500N A4 Flatbed Scanner
£819.40
Delivery:
Key features
  • High quality CCD technology
  • ReadyScan LED for immediate scanning
  • Built-in Network Interface Panel
  • Simple one-touch scanning
Product codes
This device is specially designed to accommodate documents individually, and is ideal for users with specific capture needs, such as scanning bound materials and thick or fragile documents. This scanner can be easily integrated into vertical applications thanks to TWAIN, ISIS and WIA support, as well as Document Capture Pro connectors.
High-quality scanning results are ensured by CCD technology, innovating imaging features, such as Book Spine Correction, and improved colour dropout/enhance powered by Epson Scan. In addition, Document Capture Pro makes it easy to treat scanned data before its conversion and distribution in virtually any document repository or document management system.
This scanner and its features can be shared between multiple users using the built-in Network Interface Panel. Combined with Document Capture Pro solutions, the Network Interface Panel allows users to benefit from Push Scan features and customise ‘scan to’ job functions, such as ‘scan to email’ or ‘scan to Microsoft SharePoint®’, among others*2. These features enable complicated tasks to be carried out effortlessly, increasing users' acceptance and eliminating training requirements.
Epson ReadyScan LED technology eradicates warm-up time, guarantees an absence of mercury, and lowers power consumption. These elements creates an environmentally friendly device.
Product Description Epson WorkForce DS-5500N - flatbed scanner - USB 2.0, LAN
Device Type Flatbed scanner
Interface Type USB 2.0, LAN
Additional Functions Email, scan to print, scan to network share, scan to server
Max Supported Document Size A4 (210 x 297 mm)
Input Type Colour
Optical Resolution 1200 dpi x 1200 dpi
Max Document Size 210 mm x 297 mm
Supported Document Type Plain paper
Document Feeder Type Manual
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4.x, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Citrix Presentation Server 4.5, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6
Dimensions (WxDxH) 49.5 cm x 36 cm x 12.9 cm
Weight 6 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson WorkForce DS-550...
£819.40
