Epson WorkForce DS-570W WiFi Sheetfed A4 Document Scanner
£600.58
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Scan documents easily to mobile, tablet and Wi-Fi-enabled work stations
  • Scan crumpled, long or fragile documents without increasing file sizes
  • Prevents tedious double feeds ensuring every piece of paper gets scanned
  • Quickly process physical documents in manageable amounts
  • Easy sharing between users with push scan and pre-defined job profiles
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: A4 (210 x 297 mm)
  • Interface: USB 3.0, Wi-Fi
  • Compatibility: Mac, PC
Product codes
Intelligent features improve efficiency, accuracy and data reliability
With an industry-first slow mode for scanning crumpled or fragile documents, the ability to scan challenging media has never been easier. The Active Separation Roller System prevents tedious document double feeds and the Double Feed Detection Skip (DFDS) means you can scan difficult media like envelopes or documents with post-it notes. Auto Scan Mode enables the processing of a vast number of documents as one file.
Highly versatile
Single-pass double-sided scanning ensures rapid document processing, while it's possible to scan a versatile array of media such as paper as thin as 27gsm, or thick card at 413gsm. The instantly-recognised A3 carrier sheet automatically stitches larger documents back together digitally.
Flexible connectivity
Scan documents easily to mobile, tablet and Wi-Fi-enabled work stations with its wireless capability. Built-in NFC enables instant Wi-Fi connectivity. It has high-speed USB 3.0 with TWAIN and WIA drivers for enhanced compatibility with Document Management Systems.
Image enhancement and document management software
Epson Scan 2.0 software makes it easy to edit images with features such as de-skew and auto rotate, while Document Capture Pro is the easy to use solution for capturing and storing electronic documents at the touch of a button.
Product Description Epson WorkForce DS-570W - document scanner - desktop - USB 3.0, Wi-Fi
Device Type Document scanner - desktop
Interface Type USB 3.0, Wi-Fi
Light Source LED
Additional Functions Email, scan to print, scan to network share, scan to FTP, scan to folder, scan to SharePoint
Max Supported Document Size A4 (210 x 297 mm)
Input Type Colour
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 35 ppm (mono) / 35 ppm (colour)
Max Document Size 216 mm x 6096 mm
Automatic Duplexing Yes
Supported Document Type Plain paper
Document Feeder Type Automatic
Document Storage Capacity 50 sheets
Duty Cycle 4000 scans per day
System Requirements Linux, Apple MacOS X, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Microsoft Windows Server 2012 (64-bit)
Dimensions (WxDxH) 29.6 cm x 16.9 cm x 17.6 cm
Weight 3.7 kg
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson WorkForce DS-570...
£600.58
