Epson WorkForce DS-70000 A3 High Speed Scanner Kofax VRS Cert...
Epson WorkForce DS-70000 A3 High Speed Scanner Kofax VRS Certified
£4,101.37
Delivery:
Key features
  • 70ppm/140ipm scanning speed
  • 200 A3-page ADF
  • Double Feed Detection
  • Optional Network Interface Panel
  • ENERGY STAR-qualified *1
Product codes
Documents
The Epson WorkForce DS-70000 offers reliable, high-quality document capture, conversion and distribution into document management systems. This A3 document scanner is ideal for companies with heavy scanning needs.
Designed to fit into complex IT systems effortlessly, this high-performance device can handle large batches of documents in a single go, quickly and efficiently. With a scanning speed up to 70 ppm/140 ipm, this production scanner ensures heavy duty jobs are performed effortlessly. This scanner provides fast and trouble-free scanning due to a 200 A3-page ADF, one-pass duplex scanning, and double feed detection.
Document Capture Pro makes it easy to integrate this scanner into your document management system, speeding up workflow and enabling users to capture, convert and distribute scanned information in virtually any document repository or document management system.
Demo Video
Product Description Epson WorkForce DS-70000 - document scanner - USB 2.0
Device Type Document scanner
Interface Type USB 2.0
Max Supported Document Size A3 (297 x 420 mm)
Input Type Colour
Grayscale / Color Depth 8-bit (256 colours) / 16-bit (64k colours)
Grayscale / Color Depth (External) 24-bit (16.7 million colours) / 48-bit colour
Optical Resolution 600 dpi x 600 dpi
Interpolated Resolution 9600 dpi x 9600 dpi
Max Document Scan Speed 70 ppm (mono) / 70 ppm (colour)
Max Document Size 297 mm x 2540 mm
Automatic Duplexing Yes
Supported Document Type Plain paper
Document Feeder Type Automatic
Document Storage Capacity 200 sheets
Duty Cycle 8000 scans per day
Power AC 120/230 V
System Requirements Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4.x, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Citrix Presentation Server 4.5, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6
Dimensions (WxDxH) 64 cm x 52.2 cm x 28.9 cm
Weight 26.9 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Resources
The following resources are available for the Epson WorkForce DS-70000 A3 High Speed Scanner Kofax VRS Certified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson WorkForce DS-700...
£4,101.37
