The Epson WorkForce DS-7500N can handle large batches of documents in a single go, quickly and efficiently. With a scanning speed up to 40ppm/80ipm, this departmental scanner ensures fast and trouble-free scanning due to a 100-page ADF, one-pass duplex scanning, and Double Feed Detection.
Epson Document Capture Pro makes it easy to integrate high-speed scanning into your document management system, speeding up workflow and enabling users to capture, convert and distribute scanned information in virtually any document repository or document management system.
The scanner and its features can be shared between multiple users using the built-in Network Interface Panel. Combined with Document Capture Pro, the Network Interface Panel allows users to benefit from Push Scan features and customise 'scan to' job functions, such as 'scan to email' or 'scan to Microsoft SharePoint ', among others. You can also benefit from its optional Push Scan features to increase productivity. These features enable complicated tasks to be carried out effortlessly, increasing users' acceptance and eliminating training requirements.
Epson ReadyScan LED technology eradicates warm-up time, guarantees an absence of mercury, and lowers power consumption. These elements create an environment friendly device for your office workspace.
Product Description | Epson WorkForce DS-7500N - document scanner - USB 2.0, LAN | Device Type | Document scanner | Interface Type | USB 2.0, LAN | Additional Functions | Email, scan to print, scan to network share, scan to server | Max Supported Document Size | A4 (210 x 297 mm) | Input Type | Colour | Optical Resolution | 1200 dpi x 1200 dpi | Max Document Scan Speed | 40 ppm (mono) / 40 ppm (colour) | Max Document Size | 216 mm x 1016 mm | Automatic Duplexing | Yes | Supported Document Type | Plain paper | Document Feeder Type | Automatic | Document Storage Capacity | 100 sheets | Duty Cycle | 4000 scans per day | Power | AC 120/230 V (50/60 Hz) | System Requirements | Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4.x, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Citrix Presentation Server 4.5, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6 | Dimensions (WxDxH) | 49.5 cm x 36 cm x 21.7 cm | Weight | 9.8 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Scanner | |
Max Document Scan Speed B/W | 40 ppm |
Max Document Scan Speed Colour | 40 ppm |
Scanner Speed Details | 80 ipm - colour , 80 ipm - black & white |
Scanner Features | EPSON ReadyScan LED Technology, Remove Punch Hole, RGB Color Dropout |
Compliant Standards | TWAIN, ISIS, WIA |
Media Handling | |
Expansion / Connectivity | |
Interfaces | USB 2.0 - Type B , LAN |
Miscellaneous | |
Cables Included | 1 x USB cable |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational (Standby) | 49 Watt (4.8 Watt) |
Software / System Requirements | |
Software Included | EPSON Scan, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for MAC, EPSON Document Capture Pro |
OS Required | Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4.x, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Citrix Presentation Server 4.5, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6 |
Dimensions & Weight | |
Width | 49.5 cm |
Depth | 36 cm |
Height | 21.7 cm |
Weight | 9.8 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% |
