Epson WorkForce DS-780N Document scanner Duplex A4 600dpi
£723.56
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Quick, easy connection and setup with IC card and LDAP login
  • 100-sheet ADF and 45ppm scanning at 300dpi
  • Central device and job management and lockable control panel
  • Industry first slow mode and double-feed detection skip
  • Intuitive touchscreen controls for easy job processing
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: A4 (210 x 297 mm)
  • Interface: Gigabit LAN, USB 3.0
  • Stock Status: In Stock
Product codes
Fast, high-volume scanning
The DS-780N is designed for high-volume network scanning, with a 100-sheet automatic document feeder (ADF), very fast colour scanning speeds of 45ppm/90ipm at 300dpi, and USB 3.0 to enable direct-to-PC connection.
Smart features improve workflow
Innovative features make scanning easy, including industry first slow mode for delicate documents and double-feed detection skip to allow scanning of items such as envelopes and documents with Post-its. An intuitive colour LCD touchscreen panel makes scanning easy, and allows job creation without accessing a computer.
Built-in networking and security features
The DS-780N with built-in networking is the perfect solution for creating a scanner fleet. Epson's Document Capture Pro 2.0 software offers complete control and security, allowing job, group, device and access protocols to be managed centrally. User authentication can be enabled via pin code, third-party IC card or user directory (LDAP), with a lockable control panel to prevent tampering. Pre-defined job profiles help ensure scans are sent to the correct locations.
Usage reports and maintenance alerts
Using Epson Device Admin or Document Capture Pro Server, the DS-780N can alert the administrator if it needs maintenance, and provides detailed usage reports showing which devices are used most and how many scans they've made, for effective fleet management.
Product Description Epson WorkForce DS-780N - document scanner - desktop - USB 3.0, Gigabit LAN
Device Type Document scanner - desktop
Interface Type USB 3.0, Gigabit LAN
Additional Functions Scan to network share, scan to FTP, scan to SharePoint, scan to email
Max Supported Document Size A4 (210 x 297 mm)
Localisation United Kingdom
Input Type Colour
Grayscale / Color Depth 10-bit grey / 30-bit colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 45 ppm (mono) / 45 ppm (colour)
Max Document Size 215.9 mm x 6096 mm
Automatic Duplexing Yes
Document Feeder Type Automatic
Document Storage Capacity 100 sheets
Duty Cycle 5000 scans per day
System Requirements Linux, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Microsoft Windows Server 2012 (64-bit), Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
Dimensions (WxDxH) 29.6 cm x 21.2 cm x 21.7 cm
Weight 3.7 kg
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson WorkForce DS-780...
£723.56
