EPSON WorkForce DS-860 High Speed Scanner Kofax VRS Certified
Key features
  • High-speed scanning of up to 65ppm / 130ipm, even at 300dpi in colour
  • Document Capture Pro
  • WIA, TWAIN and ISIS
  • JPEG hardware compression
Product codes
Easy network sharing via Ethernet
Optional Network Interface Unit is also available.
Product Description Epson WorkForce DS-860 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Light Source LED
Max Supported Document Size A4 (210 x 297 mm)
Input Type Colour
Grayscale / Color Depth 16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 65 ppm (mono) / 65 ppm (colour)
Max Document Size 216 mm x 356 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, plastic card
Document Feeder Type Automatic
Document Storage Capacity 80 sheets
Duty Cycle 6000 scans per day
System Requirements Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8, Microsoft Windows Server 2012 x64 Edition
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 30 cm x 16.6 cm x 15.8 cm
Weight 4 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
EPSON WorkForce DS-860...
