Epson WorkForce DS-860N High Speed A4 Network Scanner
Key features
  • Combined with Document Capture Pro, the Network Interface Unit lets you customise 'scan to' job commands
  • Text enhancement and automatic de-skew help improve efficiency
  • High-speed scanning of up to 65ppm / 130ipm, even at 300dpi in colour
  • Document Capture Pro
  • WIA, TWAIN and ISIS
Product codes
Performance and productivity
This scanner features a compact footprint and high speed scanning of up to 65ppm / 130ipm, even at 300dpi in colour. This, combined with hardware JPEG compression, makes large scan jobs faster to process. Its ReadyScan technology certifies mercury-free products and guarantees no warm-up time before scanning.
Seamless integration into document management and cloud systems
Epson Document Capture Pro makes it easy to integrate this business scanner into your document management system, speeding up workflow and enabling you to capture, convert and distribute scanned information into your document filing system. In addition, barcode recognition and Zonal OCR help automate large document processes. It can also Push Scan from the device, via network or USB, which helps to increase office productivity.
Scan software included
Epson Scan offers a wide selection of advanced document imaging features, such as text enhancement and automatic de-skew, which help improve efficiency and increase workload output. It also scans to .docx, .xlsx and .pptx.
Easy network sharing via Ethernet
Combined with Document Capture Pro, the Network Interface Unit allows you to customise 'scan to' job commands, such as 'scan-to-email', 'scan-to-Microsoft SharePoint ' or 'Scan-to-Cloud', among others, directly from the scanner's panel.
Product Description Epson WorkForce DS-860N - document scanner - desktop - LAN
Device Type Document scanner - desktop
Interface Type LAN
Light Source LED
Max Supported Document Size A4 (210 x 297 mm)
Input Type Colour
Grayscale / Color Depth 16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 65 ppm (mono) / 65 ppm (colour)
Max Document Size 216 mm x 356 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, plastic card
Document Feeder Type Automatic
Document Storage Capacity 80 sheets
Duty Cycle 6000 scans per day
System Requirements Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8, Microsoft Windows Server 2012 x64 Edition
Dimensions (WxDxH) 30 cm x 16.6 cm x 15.8 cm
Weight 4 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
