Epson WorkForce Pro WF-3720DWF Colour Ink-Jet Multifunction P...
Epson WorkForce Pro WF-3720DWF Colour Ink-Jet Multifunction Printer
£103.28
Delivery:
Key features
  • 4-in-1with fast duplex printing
  • 20ppm in black 10ppm in colour
  • Wi-Fi, Wi-Fi Direct, NFC and Ethernet
  • 250-sheet capacity
  • Freedom to print and scan anywhere
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
Product codes
Style and substance
With its modern design, the compact WF-3720DWF is a great fit for the home or office. Its stylish and sleek design is complemented by a 6.8cm touchscreen.
Business quality
Even at high speeds, this 4-in-1 printer produces top quality, laser-like prints thanks to Epson's most advanced printhead technology, PrecisionCore. The WF-3720DWF is designed for business with double-sided printing, a 35 page automatic document feeder and 250 sheet paper tray. It also supports advanced Scan-to functions including Scan-to: Email, Cloud, FTP and Network.
Low running costs
Achieve professional, crisp and clear business documents that are water, smudge and highlighter resistant, with Epson's DURABrite Ultra Ink. Offering great value, the inks are supplied individually, so you only ever have to replace the colour used. Plus, with XL cartridges you can print up to three times more pages - that equates to 1,100 black and 950 colour pages4.
Print from anywhere
From your home or office, there's the option to use Wi-Fi connectivity or Wi-Fi Direct for printing from compatible wireless devices without a Wi-Fi network. You can also print via NFC with a simple tap of a compatible Android device on the printer . And there's Epson's free mobile printing apps and solutions including Email print, which allows you to send items to print from almost anywhere in the world .
Product Description Epson WorkForce Pro WF-3720DWF - multifunction printer - colour
Device Type Multifunction printer
Fax Type Super G3 - plain paper
Printing Technology Ink-jet (colour)
Inkjet Technology Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max) 20000 pages
Max Printing Speed Up to 33 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution Up to 4800 x 2400 dpi (mono) / up to 4800 x 2400 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Scanning 1200 x 2400 dpi
Original Size A4 (210 x 297 mm) (max)
Original Type Sheets
Document Feeder Capacity 35 sheets
Media Size Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper
Standard Media Capacity 250 sheets
Output Trays Capacity 80 sheets
Automatic Duplexing Yes (printing)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled Yes
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 42.5 cm x 37.8 cm x 24.9 cm
Weight 8.6 kg
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson WorkForce Pro WF...
£103.28
