Environmentally-conscious
With up to 80% lower energy consumption than competitive colour lasers , the WF-6090DW cuts your environmental impact. Relying on clean technology, it produces no fan noise when not printing, no heat and no ozone gas.
Low running costs
With an up to 50% lower cost per page and a lower total cost of ownership compared to competitive colour laser printers , the WF-6090DW will save businesses money. With colour duplex printing, it also saves paper.
Less intervention and high reliability
Using Epson's XXL ink cartridges, the WF-6090DW can print up to 10,000 pages in black and 7,000 pages in colour, which is equal to or better than colour laser equivalents4. The maximum paper capacity of 1,581 pages means less time spent refilling.
Fast printing
With a colour first page out time of just seven seconds , the WF-6090DW is perfect for printing small print jobs quickly.
Smart control
Print to the WF-6090DW wirelessly with NFC pairing from Android smart devices, or email documents from remote locations for instant printing on the WF-6090DW. Epson Device Admin makes it easy to manage a fleet of devices remotely.
Product Description | Epson WorkForce Pro WF-6090DW - printer - colour - ink-jet | Printer Type | Workgroup printer - ink-jet - colour | Weight | 28 kg | Inkjet Technology | Epson PrecisionCore | Ink Palette Supported (Colours) | 4-ink - cyan, magenta, yellow, black | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Print Speed | Up to 34 ppm - B/W , Up to 34 ppm - colour , Up to 24 ppm - B/W (ISO/IEC 24734) , Up to 24 ppm - color (ISO/IEC 24734) , Up to 16 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 16 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm) | Max Resolution (B&W) | 4800 x 1200 dpi | Max Resolution (Colour) | 4800 x 1200 dpi | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n), NFC | AirPrint Enabled | Yes | Language Simulation | PCL 5E, PCL 5C, PostScript 3, PCL 6, EPSON ESC/P Raster, PDF 1.7 | Media Type | Envelopes, plain paper | Total Media Capacity | 580 sheets | Media Handling | 500-sheet input tray, 1-sheet manual tray, 80-sheet multipurpose tray | Monthly Duty Cycle (max) | 65000 pages | Networking | Print server | Power | AC 230V | System Requirements | Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Apple MacOS X 10.9.x | Dimensions (WxDxH) | 47.8 cm x 52.2 cm x 40.4 cm |
General | |
Printer | |
Nozzle Configuration | 800 nozzles (per cartridge) |
Minimum Ink Droplet Size | 3.7 pl |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Type | Epson DURABrite Pro inks |
Connectivity Technology | Wireless |
First Print Out Time B/W | 7 sec |
First Print Out Time Colour | 7 sec |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm |
Envelope Sizes | US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm) |
Media Weight | 64 g/m² - 256 g/m² |
Media Feeders | 1 x automatic - 500 sheets , 1 x automatic - 80 sheets , 1 x manual - 1 sheet |
Max Media Capacity | 1581 sheets |
Output Trays Capacity | 250 sheets |
Duty Cycle | |
Networking | |
Remote Management Protocol | SNMP, IPP, HTTP |
Security Protocols & Features | SSL, WEP, WPA-PSK, WPA2, IPsec, 802.1x, TKIP, AES, PING, Wi-Fi Direct |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) |
Power | |
Power Device | Power supply - internal |
Voltage Required | AC 230V |
Power Consumption Operational | 37 Watt |
Power Consumption Stand by | 8.1 Watt |
Power Consumption Sleep | 2.1 Watt |
Software / System Requirements | |
OS Required | Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Apple MacOS X 10.9.x |
Environmental Parameters | |
Sound Emission (Operating) | 49 dBA |
Dimensions & Weight | |
Width | 47.8 cm |
Depth | 52.2 cm |
Height | 40.4 cm |
Weight | 28 kg |
