Epson WorkForce Pro WF-8090DW A3+ Colour Inkjet Printer
£974.97
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Low total cost of ownership duplex printer
  • Uses up to 80 percent less power than competitive colour lasers
  • PDL emulations, Gigabit Ethernet, Wi-Fi and Wi-Fi direct
  • Automatic double-sided printing, and scalable paper capacity for less refilling
  • Epson's most advanced printhead technology
Product codes
Low TCO printing
Take advantage of a low Total Cost of Ownership (TCO) and print up to 7,000 colour and 10,000 mono pages using, easy-to-change, high-capacity DURABrite Pro ink cartridges.
Ecological
The WF-8090DW uses up to 80 percent less power than competitive colour lasers thanks to its no heat technology. No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing make it ideal for the workplace. And there are fewer parts to replace than a laser.
Enhance productivity
Print at up to 34 pages per minute (ppm) in both colour and mono, with ISO print speeds of 24 ppm for both . The WF-8090DW delivers automatic double-sided A4 and A3 printing for eco-friendly and business-quality results. Scalable optional paper trays take its maximum capacity to 1,831 sheets, and the rear manual paper tray lets you print A3+ and onto a range of media.
Built for business
PrecisionCore technology powers the output quality and reliability that Epson is known for, at the speeds required for office, commercial and industrial printing. Wi-Fi and Wi-Fi Direct allow for easy integration and printing from smartphones and tablets. Users can also securely print using a PIN code to release jobs at the printer, or by using Email Print for Enterprise4 to securely send documents directly to the printer.
Epson WorkForce Pro WF-8090DW - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
25.9 kg
Inkjet Technology
Epson PrecisionCore
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A3
Max Media Size
A3 Plus (329 x 483 mm)
Print Speed
Up to 34 ppm - B/W , Up to 34 ppm - colour , Up to 24 ppm - B/W (ISO/IEC 24734) , Up to 24 ppm - color (ISO/IEC 24734) , Up to 16 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 16 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
4800 x 1200 dpi
Max Resolution (Colour)
4800 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
Language Simulation
PCL 5E, PCL 5C, PostScript 3, PCL 6, EPSON ESC/P Raster, PDF 1.7
Media Type
Envelopes, plain paper
Total Media Capacity
330 sheets
Media Handling
250-sheet input tray, manual bypass slot, 80-sheet multipurpose tray
Monthly Duty Cycle (max)
65000 pages
Print server
AC 230V
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Apple MacOS X 10.9.x
1 year warranty
56.7 cm x 57 cm x 37.8 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson WorkForce Pro WF...
£974.97
