Epson WorkForce Pro WF-8590DWF A3+ Colour Inkjet MFP
Key features
  • Multifunction printer with scalable paper trays
  • Uses up to 80 percent less power than competitive colour lasers
  • Epson's most advanced printhead technology
  • Automatic double-sided printing, scanning, copying and faxing
Product codes
Low TCO printing
Take advantage of a low Total Cost of Ownership (TCO), and print up to 7,000 colour and 10,000 mono pages using easy-to-change, high-capacity DURABrite Pro ink cartridges.
Ecological
Uses up to 80% less power than competitive colour lasers thanks to the no heat technology. No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing make it ideal for the workplace. And there are fewer parts to replace than a laser.
Enhance productivity
Print at up to 34 pages per minute (ppm) in both colour and mono, with ISO print speeds of 24 ppm for both . The WF-8590DWF delivers automatic double-sided A4 and A3 printing for eco-friendly and business-quality results, and features one-pass duplex scanning and a 50-sheet Automatic Document Feeder. Scalable optional paper trays take its maximum capacity to 1,831 sheets.
Built for business
Epson's PrecisionCore technology powers the output quality and reliability at the speeds required for both office and industrial printing. A smartphone-like 12.7cm colour touchscreen is easy to use, while scan-to functions, including Microsoft SharePoint4, and LDAP address book compatibility make it ideal to share documents. Also securely print using a PIN code to release confidential documents, or use Email Print for Enterprise5 to securely send documents directly to the multifunction printer.
Product Description Epson WorkForce Pro WF-8590DWF - multifunction printer - colour
Device Type Multifunction printer
Fax Type Super G3 - plain paper
Printing Technology Ink-jet (colour)
Inkjet Technology Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max) 65000 pages
Max Copying Speed Up to 22 ppm (mono) / up to 21 ppm (colour)
Max Copying Resolution Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Printing Speed Up to 34 ppm (mono) / up to 34 ppm (colour)
Max Printing Resolution Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Scanning 1200 x 2400 dpi
Original Size A3 (297 x 420 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size A3 Plus (329 x 483 mm) (max)
Media Type Envelopes, plain paper, photo paper
Standard Media Capacity 330 sheets
Max Media Capacity 1831 sheets
Bypass Feeder Capacity 80 sheets
Output Trays Capacity 250 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, save to USB flash drive, scan to Cloud
Power AC 230 V
Dimensions (WxDxH) 59 cm x 57 cm x 46.4 cm
Weight 34.3 kg
Environmental Standards ENERGY STAR Qualified
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson WorkForce Pro WF...
