Epson WorkForce WF-2750DWF A4 Colour Inkjet Printer
Key features
  • Laser-like results
  • Scan, copy, print and fax
  • Print wirelessly wherever you are
  • Only replace the colour used
  • 150 page front-loading paper tray
Product codes
Small business and home office users should look no further than this compact 4-in-1. The WF-2750DWF boasts double-sided, business-quality printing and individual inks for cost savings. It also features Wi-Fi and Wi-Fi Direct® and is compitable with Epson Connect1 to ensure quick and easy mobile printing.
Business quality
This 4-in-1 printer uses a PrecisionCore printhead to ensure top quality, laser-like performance. Fast print speeds and a 30-page automatic document feeder for multi-page, 1200dpi scanning, copying and faxing offer the ultimate in convenience. Wi-Fi and Wi-Fi Direct connectivity ensure the flexibility every small business needs.
Low running costs
The WF-2750DWF uses Epson's 16 series Pen and Crossword inks, available in a choice of standard or XL cartridges sizes to suit your specific printing needs. XL inks can help you to reduce your printing costs by up to 25% . The use of individual ink cartridges means only the colour used will need to be replaced, further reducing costs.
Mobile printing
Epson Connect compatibility offers useful features like scan-to-cloud, email print and the Epson iPrint app . The WF-2750DWF is also compatible with Apple AirPrint and Google Cloud print, letting you print seamlessly from smartphones and tablets.
Easy to use
Automatic Wi-Fi set-up4 helps make connection a breeze, while the 150-sheet front-loading paper cassette makes refilling easy. A 5.6cm LCD screen and a user-friendly menu makes navigating the WF-2750DWF simple and quick.
Product Description Epson WorkForce WF-2750DWF - multifunction printer - colour
Device Type Multifunction printer
Fax Type Super G3 - plain paper
Printing Technology Ink-jet (colour)
Inkjet Technology Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max) 3000 pages
Max Printing Speed Up to 33 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Scanning 1200 x 2400 dpi
Original Type Sheets
Document Feeder Capacity 30 sheets
Media Size Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Standard Media Capacity 150 sheets
Output Trays Capacity 30 sheets
Automatic Duplexing Yes (printing)
Connection Availability Yes
Interface USB 2.0, Wi-Fi(n)
AirPrint Enabled Yes
Office Machine Features Scan to Cloud
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 42.5 cm x 36 cm x 23 cm
Weight 6.6 kg
Environmental Standards ENERGY STAR Qualified
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
