Epson XP-860 A4 Colour Wireless Inkjet 3 in 1
Key features
  • Claria Photo HD inks for exceptional, long-lasting photos
  • Wi-Fi and Ethernet connectivity and easy mobile printing
  • One for A4 and another for photo paper
  • Prints on thick card & CD/DVDs
  • Save paper and money and reduce your environmental impact
Product codes
Superior results
The XP-860 uses Epson's Claria Photo HD ink, a six-colour inkset that is ideal for producing superior-quality, long-lasting photographs. It delivers smooth tonal gradations, natural blacks and rich, vibrant colours for high-quality photos.
Mobile printing
Epson Connect consists of Epson iPrint – for easy wireless printing from smartphones and tablets; Epson Creative Print – print photos directly from Facebook, and Epson Email print – print from anywhere in the world by emailing photos and documents directly to the printer. AirPrint and Google Cloud Print are also supported.
Wireless connectivity
Automatic Wi-Fi set-up4 makes it quick and simple to connect to a Wi-Fi network, or alternatively compatible devices can be connected via Wi-Fi Direct without having to connect to a wireless router. Printing is also possible from Wireless PictBridge-compatible cameras.
Versatile printing
In addition to dual paper trays, the rear speciality media feed enables printing onto thick card and photo paper for extra creativity. Printing onto suitable CDs and DVDs is also possible. Fast print speeds mean you can print photos in just 10 seconds5.
Easy to control
The XP-860 has a 10.9cm interactive LCD touchscreen, and printing directly from a memory card is easy. A motorised control panel and automatic-opening output tray make for hassle-free printing.
Epson Expression Photo XP-860 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 6-ink
Max Printing Speed
Up to 32 ppm (mono) / up to 32 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 200 x 200 dpi
Scanning
4800 x 4800 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to Cloud
AC 230 V (50/60Hz)
39 cm x 33.9 cm x 19.1 cm
8.3 kg
Microsoft Certification
Compatible with Windows 7
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson XP-860 A4 Colour...
