EVGA 600W 80+ Power Supply
£46.41
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Excellent acoustics
  • Heavy-duty power protections
Product codes
Ready for 4th Generation Intel Core Processors (C6/C7 Idle Mode)
When building on a budget, the EVGA 600W 80 PLUS is a great choice at a low cost. Supporting 49A on a single +12V rail provides more options without having to reduce your component requirements. Save space with the 600W's compact design, well-placed power switch and fully sleeved cables. The 600W offers the connections and protections needed for basic system builds. With a standard 3 year warranty and ultra quiet fan design the 600W will be a great asset for your next build on a budget.
FEATURES
Quiet and Intelligent Auto Fan for near-silent operation
3 Year Warranty
Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), SCP (Short Circuit Protection), and OTP (Over Temperature Protection)
EVGA 600 W1 - power supply - 600 Watt
Power supply - internal
Specification Compliance
ATX12V / EPS12V
80 PLUS Certification
80 PLUS
1.81 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output connectors
1 x power 24 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.5 cm
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
EVGA 600W 80+ Power Su...
£46.41
