EVGA NVIDIA GeForce GTX 1050 SC GAMING 2GB GDDR5 Graphics Card
£151.51
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • NVIDIA GameStream technology
  • NVIDIA G-SYNC Ready
  • OpenGL 4.5 Support
  • Simultaneous Multi-Projection
  • NVIDIA Ansel
  • NVIDIA GPU Boost 3.0
  • Microsoft DirectX 12
  • Vulkan API
  • PCI Express 3.0
  • Max Digital Resolution - 7680x4320
  • HDMI 2.0b, DisplayPort 1.4 and Dual-Link DVI
  • Built for EVGA Precision XOC
  • Graphics Processor Manufacturer: NVIDIA
  • Graphics Processor: NVIDIA GeForce GTX 1050, NVIDIA GeForce GTX 1050, NVIDIA GeForce GTX 1050
  • Interface: PCI Express 3.0 x16
  • Memory Size: 2GB, 2GB
  • Stock Status: In Stock
Product codes
he EVGA GeForce GTX 1050 Ti hits the perfect spot for that upgrade you know you need, but at the price you want! With the latest NVIDIA Pascal architecture, the 4GB GTX 1050 Ti displays stunning visuals and great performance at 1080p HD+.
Installing a EVGA GeForce GTX 1050 Ti gives you the power to take on today next-gen titles in Full 1080p HD with room to spare. These cards give you a choice of memory sizes, cooling options, factory overclocks, and power options to fit every need and every system. Of course, no GTX card would be complete without essential gaming technologies, such as NVIDIA GameStream, G-Sync, and GeForce Experience.
If you've been waiting for that card that gives you the performance to take back the competitive edge, but without taking out your wallet, then the GTX 1050 Ti is the card for you!
Product Description EVGA GeForce GTX 1050 SC Gaming - graphics card - NVIDIA GeForce GTX 1050 - 2 GB
Device Type Graphics card
Bus Type PCI Express 3.0 x16
Graphics Engine NVIDIA GeForce GTX 1050
Memory 2 GB GDDR5
Core Clock 1417 MHz
Boost Clock 1531 MHz
CUDA Cores 640
Effective Memory Clock 7008 MHz
Memory Interface 128-bit
Max Resolution 7680 x 4320
Max Monitors Supported 3
Interfaces DisplayPort , DVI-D (dual link) , HDMI
API Supported DirectX 12, OpenGL 4.5, Vulkan
Dimensions (WxDxH) 14.478 cm x 11.115 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
EVGA NVIDIA GeForce GT...
£151.51
