EVGA SuperNOVA 650 P2 650W Platinum PSU
£121.70
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fully modular to reduce clutter and improve airflow
  • High reliability and quiet operation
  • Heavy-duty protection
  • Power Rating: 650Watt
  • Stock Status: In Stock
Product codes
The unbeatable performance of the EVGA SuperNOVA P2 power supply line is now available in 650 watts. Based on the award winning P2 power supplies, this unit features 80 Plus Platinum rated efficiency, and clean, continuous power to every component. The ECO Control Fan system offers fan modes to provide absolutely zero fan noise during low load to medium load operations. Backed by an award winning 10 year warranty, and 100% Japanese capacitor design, the EVGA SuperNOVA 650 P2 power supply offers unbeatable performance at an unbeatable value.
• Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
• Highest quality Japanese brand capacitors ensure long-term reliability
• Fully Modular to reduce clutter and improve airflow
• NVIDIA SLI & AMD Crossfire Ready
• Double Ball Bearing fan for exceptional reliability and quiet operation
• Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
• 80 PLUS Platinum certified, with 92% (115VAC) / 94% (220VAC~240VAC) efficiency or higher under typical loads
Product Description EVGA SuperNOVA 650 P2 - power supply - 650 Watt
Device Type Power supply - internal
Specification Compliance ATX / EPS
80 PLUS Certification 80 PLUS Platinum
Weight 2.72 kg
Localisation United Kingdom
Input Voltage AC 100-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 650 Watt
Output connectors 1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 2 x 6 pin PCI Express power , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System 140 mm fan
Included Accessories Cable bag
Dimensions (WxDxH) 15 cm x 16.5 cm x 8.5 cm
Manufacturer Warranty 10-year warranty with product registration
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
EVGA SuperNOVA 650 P2...
£121.70
