EVGA TORQ X5L DPI-8200 Mouse
Key features
  • Onboard storage can support up to 5 separate profiles
  • Ambidextrous design supports right or left handed gamers
  • Adjustable DPI with On-the-Fly Sensitivity adjustment
  • Highest quality materials and Omron switches
  • Robust software allows full control over mouse including Macro setup, profiles and OSD
  • Super low friction PTFE mouse feet
Product codes
Built with the highest quality materials, this mouse was designed from the ground up to satisfy the needs of the hardcore gamer with a high quality laser sensor that provides up to 8200 DPI, eight programmable buttons, and a customizable RGB LED.
The EVGA TORQ X5L features the highest quality Omron switches with a lifespan of over 20 million clicks, 512Kb of onboard storage for saving up to 5 seperate profiles, robust tuning software, the Avago 9800 laser sensor providing up to 8200DPI with 1000Hz polling rate, and much more.
Product Description EVGA TORQ X5L - mouse - USB
Device Type Mouse
Connectivity Technology Wired - USB
Orientation Right and left-handed
Dimensions (WxDxH) 6.477 cm x 11.786 cm x 3.8862 cm
Weight 92 g
Movement Detection Technology Laser
Buttons Qty 8
Movement Resolution 8200 dpi
Performance Polling rate: 1000 Hz
Features Scrolling wheel, polytetrafluoroethylene (PTFE) feet, 7-colour LED, On-The-Fly Sensitivity, 5 profiles, On-screen Display (OSD), Avago 9800 sensor, 8 programmable buttons, OMRON switches
Manufacturer Warranty 3 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
EVGA TORQ X5L DPI-8200...
