Know who's there for what, before you open the door. The EZVIZ DB2 is a 100% wire-free doorbell kit that covers all your basic needs for front-door protection and communication. Despite its super easy installation and reliable use in all weathers, the doorbell comes with multiple advanced features including 2K video, extremely wide field-of-view, and smart motion detection.
Product Description | EZVIZ DB2 - doorbell kit - 802.11b/g/n | Product Type | Doorbell kit | Functions | Motion detection, camera | Power Source | Battery, power adapter | Package Content | Doorbell, wireless chime unit | Connectivity | Wireless - 802.11b/g/n | Frequency Band | 2.4 Ghz | Camera | CMOS 1/2.7" - Max Resolution 2000 x 1504 - audio - Day&Night | Manufacturer Warranty | 2-year warranty |
General | |
Connectivity Technology | Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Features | Weatherproof, H.264 streaming video, tamper alert, H.265 streaming video, 20 selectable ringtones |
Camera | |
Image Sensor | CMOS - 1/2.7" |
Lens Aperture | F/2.0 |
Focal Length | 2 mm |
Day & Night Functionality | Yes |
Audio Support | Yes |
Max Digital Video Resolution | 2000 x 1504 |
Features | Built-in speaker, progressive scanning, built-in microphone, reset button, 3D digital noise reduction (DNR), human detection, up to 5m night vision distance, 2D digital noise reduction (DNR), built-in 5200 mAh battery, 176° field of view (diagonal) |
Motion Sensor | |
Detection Mode | Passive infrared (PIR) |
Detection Range | 5 m |
Detection Angle | 100 degree(s) |
Flash Memory | |
Supported Flash Memory Cards | microSD |
Miscellaneous | |
Included Accessories | Screws, connector kit, mounting plate, power cable, sticker, drilling template |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK |
Compliant Standards | UL, FCC, RoHS, WEEE, REACH |
Dimensions & Weight | |
Dimensions & Weight Details | Chime: 5.5 cm x 3.5 cm x 10 cm x 120 g , Doorbell: 5.8 cm x 3.2 cm x 15 cm x 241.35 g |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
