We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Add-on camera for expanded protection.
Used together with a base station, the BC1 wire-free camera delivers well-rounded home protection for up to a full year on one single charge. The BC1 inherits EZVIZ’s core technologies of color night vision, two-way talk, active defense, and more, showcasing unparalleled usability in any household.
Product Description | EZVIZ BC1 - network surveillance camera | Device Type | Network surveillance camera - fixed - dustproof / waterproof | Audio | Yes: built-in speaker, two-way audio capability, built-in omni-directional microphone | Dimensions (WxDxH) | 6.28 cm x 10.476 cm x 6.28 cm | Weight | 1.304 kg | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Max Resolution | 1920 x 1080 | Frame Rate (max) | 30 frames per second | Motion Detection | Yes | Video Modes | 1080p | Optical Sensor Type | CMOS - 1/2.8" - 2 MP | Focal Length Control | Fixed focal | Focal Length | 2.8 mm | Lens Mounting | M12 mount | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Cables Included | 1 - USB cable | Voltage | DC 5 V | Features | Digital Wide Dynamic Range (D-WDR), PIR-based motion detector, Voice Alert, Colour Night Vision, 3D digital noise reduction (DNR), Active Defense | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -20 °C - 45 °C; 0 - 95% (non-condensing) relative humidity |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, two-way audio capability, built-in omni-directional microphone |
Width | 6.28 cm |
Depth | 10.476 cm |
Height | 6.28 cm |
Weight | 1.304 kg |
Camera | |
Type | Colour - Day&Night - fixed - dustproof / waterproof |
Digital Video Format | H.265 |
Max Digital Video Resolution | 1920 x 1080 |
Infrared LEDs | Yes |
Infrared Distance | 10 m |
Video Capture | 1920 x 1080, 50 Hz @ 25 fps , 1920 x 1080, 60 Hz @ 30 fps |
Image Sensor | |
Type | 2 MP CMOS 1/2.8" |
Lens Construction | |
Type | M12 mount - fixed focal |
Horizontal Field of View (degree) | 108 |
Diagonal Field of View (degree) | 128 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Expansion / Connectivity | |
Supported Memory Cards | microSD Card, microSDHC Card, microSDXC Card |
Miscellaneous | |
Included Accessories | Mounting bracket, screw kit, drill hole template, magnetic base, screw base |
Cables Included | 1 x USB cable |
Compliant Standards | UL, FCC, RoHS, WEEE, REACH, IP66 |
Power | |
Power Requirements | DC 5 V |
Power Device | Power adapter 5 Watt |
Battery | Lithium Ion 12900 mAh (up to 365 days) |
Software / System Requirements | |
Software Included | Linux |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight (Shipping) | |
Shipping Width | 26 cm |
Shipping Depth | 21.7 cm |
Shipping Height | 18 cm |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
Relative Humidity (operating) | 0 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
