The BC1 wire-free camera delivers well-rounded home protection for up to a full year on one single charge. The BC1 inherits EZVIZ's core technologies of color night vision, two-way talk, active defense, and more, showcasing unparalleled usability in any household.
Product Description | EZVIZ BC1-B3 - NVR + camera(s) - wireless (802.11b, 802.11g, 802.11n) - battery powered, AC powered | System | NVR + camera(s) - wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n - 2.4 GHz - battery, power adapter | Camera | 3 cameras - night vision | Lens Mount | M12 mount | Dimensions (WxDxH) | 6.28 cm x 10.476 cm x 6.28 cm | Weight | 1.304 kg | Manufacturer Warranty | 1 year |
General | |
System | NVR + camera(s) - wireless |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Wireless Frequency Band | 2.4 GHz |
Features | 2-way audio, built-in microphone, built-in speaker, dustproof, waterproof, motion alerts, infrared cut filter |
Package Content | 3 cameras, 3 magnetic mounts, NVR, 3 screw sets, 3 screw bases, camera power adapter, NVR power adapter, 3 mounting plates, 3 drill templates |
Software Included (Y) | EZVIZ App |
Power Source | Battery, power adapter |
Warranty | 1 year |
Security DVR | |
Frame Rate (Record) | 25 fps, 30 fps |
Image Resolution | 1920x1080 |
Compression Format | H.265 |
Record Events | Motion detection |
Features | microSD card slot, smartphone support |
Cameras | |
Quantity | 3 cameras |
Sensor | CMOS - 1/2.8" - 1920x1080 |
Field of View | 108° (H), 128° (D) |
Night Vision | Yes |
Infrared Distance | 10 m |
Focal Length | 2.8 mm |
Voltage | DC 5 V |
Power Consumption | 5 Watt |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
Operating Humidity | 0-95% (non-condensing) |
Compliant Standards | IP66 |
Connections | |
Other Ports | RJ-45 |
Dimensions & Weight | |
Width | 6.28 cm |
Depth | 10.476 cm |
Height | 6.28 cm |
Weight | 1.304 kg |
Details | NVR: 8.197 cm x 8.197 cm x 16.022 cm , Camera: 6.28 cm x 10.476 cm x 6.28 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 26 cm |
Shipping Depth | 21.7 cm |
Shipping Height | 18 cm |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
