The C3TN Color covers almost every essential function you could ask for a home security camera. 1080p video quality, color night vision, active defense, IP67 weatherproof design and more, are all packaged in one, simple device. Live safer and smarter with the easy control and reliable performance that the C3TN Color offers.
Product Description | EZVIZ C3TN - network surveillance camera - bullet | Device Type | Network surveillance camera - fixed - bullet - weatherproof | Audio | Yes: built-in microphone | Dimensions (WxDxH) | 7.2 cm x 15.2 cm x 7.2 cm | Weight | 256 g | Colour | White | Connectivity Technology | Wired, wireless | Camera | Colour - Day&Night | Max Resolution | 1920 x 1080 | Frame Rate (max) | 30 frames per second | Motion Detection | Yes | Video Modes | 1080p | Optical Sensor Type | PS CMOS - 1/2.7" | Minimum Illumination | 0.01 lux F2.0 - AGC on , 0 lux - IR | Focal Length Control | Fixed focal | Focal Length | 2.8 mm | Lens Mounting | M12 mount | Lens Iris | F/2.0 | Interfaces | Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Voltage | DC 12 V | Features | Image mirror, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, cloud recording, Colour Night Vision, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker, 3D digital noise reduction (DNR), noise-cancellation, self-adaptive shutter, Adaptive Bitrate (ABR), strobe light alarm | Manufacturer Warranty | 2-year warranty | Environmental Parameters (operating) | -20 °C - 50 °C; 0 - 95% (non-condensing) relative humidity |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in microphone |
Form Factor | Bullet |
Width | 7.2 cm |
Depth | 15.2 cm |
Height | 7.2 cm |
Weight | 256 g |
Camera | |
Type | Colour - Day&Night - fixed - weatherproof |
Digital Video Format | H.264, H.265 |
Max Digital Video Resolution | 1920 x 1080 |
Infrared LEDs | Yes |
Infrared Distance | 30 m |
Digital Video Capture Resolution | 1920 x 1080 |
Image Sensor | |
Type | PS CMOS 1/2.7" |
Lens Construction | |
Type | M12 mount - fixed focal |
Lens Iris | F/2.0 |
Horizontal Field of View (degree) | 106 |
Diagonal Field of View (degree) | 122 |
Interfaces | |
Network Interface | Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Network Protocols | TLS |
Expansion / Connectivity | |
Ports | LAN - RJ-45 |
Supported Memory Cards | microSD Card, microSDHC Card, microSDXC Card |
Miscellaneous | |
Included Accessories | Screw kit, mounting template, waterproof kit |
Compliant Standards | UL, FCC, RoHS, AES-128, WEEE, REACH, IP67, TLS, UKCA |
Colour | White |
Power | |
Power Requirements | DC 12 V - 1 A |
Power Device | Power adapter - external 6 Watt |
Internet of Things (IoT) | |
Supported Host Device Platform | iOS, Android |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 22.7 cm |
Shipping Depth | 10 cm |
Shipping Height | 9.2 cm |
Shipping Weight | 500 g |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 50 °C |
Relative Humidity (operating) | 0 - 95% (non-condensing) |
