Ezviz Full HD Indoor/Outdoor Battery Cam
£149.98
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with Amazon Alexa, Google Assistant and IFTTT
  • Up to 2 months’ battery life before having to recharge, no wires!
  • Secure the interior/exterior of your home for peace of mind
  • Push notifications sent to your phone when motion is detected.
  • No hub required
  • Let’s you view, listen and speak to visitors or pets from your smartphone or PC/Mac
  • Easy Setup and Installation via the EZVIZ app
  • 2 years’ warranty and 24/7 Tech Support
  • Type: Indoor Camera, Outdoor Camera
  • Compatible With: Alexa, Google Assistant, IFTTT
  • Stock Status: In Stock
Product codes
Introducing the EZVIZ Full HD Wire-free Battery Camera
This EZVIZ camera is a weatherproof indoor/outdoor standalone 100% wire-free, battery-powered security camera with 126 Degrees viewing angle. Being wire-free enables you to effortlessly place the camera anywhere without any cables. Furthermore, no hub is required.
Be Informed
Featuring PIR technology to help reduce false triggers, it simply detects heat sources only, such as Cars, Animals and Humans. Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Baby/Elderly/Pet Monitor
Great for monitoring your pets, little ones or elderly relatives. Furthermore, with the two-way talk, you can see, hear and speak all through the EZVIZ app, whether you are at home or away!
Continuous wire-free recording
With a long-lasting 5,500mAh rechargeable battery that will last up to 2 months before having to charge, you can have peace of mind knowing that you will always be covered. Also great for wildlife monitoring e.g. Bird Boxes.
Amazon Alexa & Google Home Compatible
Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
24/7 All Season Protection
Because of its IP65 enclosure rating, the Outdoor camera will be resistant against rain, snow, and other weather conditions. With the integration of Infrared technology, footage can be seen clearly at Night too. Consider a Wi-Fi Range Extender for further connectivity
Two-way Talk
The internal waterproof microphone supports audio pickup within five meters and video recording with sound, meaning you can have a two-way conversation if needed via the EZVIZ app.
Easy Setup
Straight Forward installation with magnetic mount in the box, great for both ceiling and wall-mounted installation. For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 128GB) for local storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
Further Recommendations Consider a Wi-Fi Range Extender if you have poor connectivity around the home from your Router location
What’s in the box
  • 1x EZVIZ Full HD Wi-Fi Outdoor Smart Home Security Camera
  • 1x Power Adapter with 3 metre cable
  • 1x 5,500mAh Battery
  • 1x Magnetic Mount
  • 1x Quick Start Guide
Product Description EZVIZ C3A - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor, indoor - dustproof / weatherproof
Audio Yes: built-in speaker, built-in microphone
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 30 frames per second
Motion Detection Yes
Video Modes 1080p
Optical Sensor Type CMOS - 1/4" - 2 MP
Focal Length Control Fixed focal
Focal Length 2.2 mm
Lens Iris F/2.4
Interfaces Wi-Fi
Cables Included 1 - USB cable - external
Voltage DC 5 V
Features Saturation control, brightness control, contrast control, image mirror, automatic electronic shutter, Motion Detection Technology, infrared cut filter, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, flickerless, Variable Bitrate (VBR), cloud recording, 3D Digital Noise Reduction Technology
Environmental Parameters (operating) -25 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ezviz Full HD Indoor/O...
£149.98
