EE + BT. BETTER AS ONE. WE’RE PART OF THE SAME FAMILY.
Ezviz Full HD Indoor Smart Security Cam - 4MP H.265
FREE DELIVERY
£35.98
37 left in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • Smart night vision with Smart IR
  • Zero blind spots
  • Smart tracking
  • Communication anytime
  • Protects your privacy
  • Type: Indoor Camera
Product codes
The C6N from EZVIZ comes equipped with a Smart IR function, which uses advanced infrared (IR) lighting to capture more details in dim light. With its 360-degree field of view and smart tracking function, you won't need to worry about missing a thing.
Product Description EZVIZ C6N 4MP - network surveillance camera
Device Type Network surveillance camera - pan / tilt
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 8.8 cm x 8.82 cm x 11.9 cm
Weight 252 g
Connectivity Technology Wired, wireless
Camera Colour - Day&Night
Max Resolution 2560 x 1440
Frame Rate (max) 20 frames per second
Motion Detection Yes
Video Modes 1080p
Optical Sensor Type PS CMOS - 1/3" - 4 MP
Focal Length Control Fixed focal
Focal Length 4 mm
Lens Mounting M12 mount
Lens Iris F/2.4
Panning Range (degree) 350
Tilting Range (degree) 55
Interfaces Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage DC 5 V
Features Progressive scanning, infrared cut filter, Digital Wide Dynamic Range (D-WDR), Smart IR, reset button, Smartphone Monitoring, cloud recording, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, 3D digital noise reduction (DNR), smart tracking, self-adaptive shutter, instant notification, Adaptive Bitrate (ABR)
Environmental Parameters (operating) -10 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£35.98
