Ezviz Full HD Indoor Smart Security PT Cam, with Motion Tracking
£79.99
Delivery:
Key features
  • Compatible with Amazon Alexa, Google Assistant and IFTTT
  • 360-degree Pan/Tilt view with Automatic Motion Tracking
  • Secure the Interior of your home for peace of mind
  • Push notifications sent to your phone when motion is detected.
  • View Live or Playback HD footage at any time via the App
  • Let’s you view, listen and speak to visitors or pets from your smart phone or PC/Mac
  • Easy Setup and Installation via the EZVIZ app
  • 2 years’ warranty and 24/7 Tech Support
Product codes
Introducing the EZVIZ Pan and Tilt camera
Imagine that you are at work and an intruder has come into your home – your Pan/Tilt Wi-Fi Smart Camera will alert you straight away with a message via the EZVIZ app to your smartphone, take a snapshot and even proceed to record the events and the suspicious activity. What’s more, the C6Tc will track and follow them too, gathering up as much footage as possible.
Baby/Elderly/Pet Monitor
Great for monitoring your pets, little ones or elderly relatives. Furthermore, with the two-way talk, you can see, hear and speak all through the EZVIZ app, whether you are at home or away!
Pan/Tilt & Motion Tracking
With the 360-degree Horizontal, 80-degree vertical rotation Pan & Tilt feature, you can see everything in the room, keeping a lookout of the whole room. If it notices something moving (like the dog with something in its mouth), the camera will track the movement automatically across the room, providing the best footage possible. This can also be manually moved around via your EZVIZ smartphone app.
Be Informed Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Amazon Alexa & Google Home Compatible - Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
Secure Your Home Day & Night
The Infrared (IR) allows clear video even when it’s dark, giving clear night vision and recording, providing 24/7 security in your home or office.
Two-way Talk
The internal microphone supports audio pickup within five meters and video recording with sound, meaning you can have a two-way conversation if needed via the EZVIZ app.
Easy Setup
For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 128GB) for local storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
Works with EZVIZ Alarm Systems
Link to a specific EZVIZ alarm sensor via the app to ensure footage begins straight away when a sensor is triggered. Furthermore, one set via the app, the Pan/Tilt feature will automatically move direction towards the sensor in question helping capture the whole event from all angles.
What’s in the box
  • 1x EZVIZ HD 1080p Pan Tilt Camera
  • 1x Power Adapter with 3m Cable (3.5mm jack connection)
  • 1x Mounting Accessories and set of screws
  • 1x Quick Start Guide
Product Description EZVIZ C6T - network surveillance camera
Device Type Network surveillance camera - pan / tilt - indoor
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 10 cm x 10 cm x 9 cm
Weight 220 g
Colour White
Connectivity Technology Wired, wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 30 frames per second
Motion Detection Yes
Video Modes 720/30p, 1080/15p
Optical Sensor Type CMOS - 1/3" - 2 MP
Minimum Illumination 0.02 lux F2.0 - AGC on , 0 lux - IR
Focal Length Control Fixed focal
Focal Length 4 mm
Lens Mounting M12 mount
Lens Iris F/2.0
Panning Range (degree) 0 to 340
Tilting Range (degree) -10 to +80
Interfaces Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage DC 5 V
Features Alarm function, progressive scanning, saturation control, brightness control, contrast control, image mirror, Motion Detection Technology, infrared cut filter, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), Wi-Fi Protected Setup (WPS), Dual Stream Encoding, microSDXC card slot, password protection, auto tracking, Smartphone Monitoring, Variable Bitrate (VBR), cloud recording, 3D Digital Noise Reduction Technology, Black light compensation (BLC), WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker
Manufacturer Warranty 1-year warranty
Environmental Parameters (operating) -10 °C - 55 °C; 0 - 95% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ezviz Full HD Indoor S...
£79.99
