Ezviz Full HD Outdoor Smart Security Cam with Siren and Strob...
Ezviz Full HD Outdoor Smart Security Cam with Siren and Strobe Light
£99.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with Amazon Alexa, Google Assistant and IFTTT
  • Built in 100db alarm and Strobe light to help deter suspicious behaviour
  • Secure the exterior of your home for peace of mind
  • Push notifications sent to your phone when motion is detected.
  • View Live or Playback HD footage at any time via the App
  • Let’s you view, listen and speak to visitors from your smartphone or PC/Mac
  • Easy Setup and Installation via the EZVIZ app
  • 2 years’ warranty and 24/7 Tech Support
  • Type: Outdoor Camera
  • Compatible With: Alexa, Google Assistant, IFTTT
  • Stock Status: In Stock
Product codes
Introducing the EZVIZ Full HD Wi-Fi Outdoor Camera
This wall-mounted outdoor Wi-Fi camera uses a built-in strobe light and 100db alarm for aiding deterrence, whilst also offering two-way talk and durability in any type of weather.
Be Informed
Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are. Great for outdoor detections in the Garden or Driveway.
Reliable Connectivity
Dual antennas on the camera ensure reliable wireless transmission indoors or outdoors, to enhance the connection to and from your Wi-Fi Router, removing potential video lagging whilst maintaining good performance through the various weather conditions when placed outside.
Amazon Alexa & Google Home Compatible
Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
24/7 All Season Protection
Because of its IP66 enclosure rating, the Outdoor camera will be resistant against rain, snow, and other weather conditions. With the integration of Infrared technology, footage can be seen clearly at Night too.
Two-way Talk
Integrated with professional de-noising algorithm to filter background noise for enhanced voice quality. The internal waterproof MIC supports audio pickup within five meters and video recording with sound via the EZVIZ app.
Easy Setup
Straight Forward installation with drill template included in the box. The camera itself has a Cardan shaft rotation for various angles, great for both ceiling and wall-mounted installation. For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 128GB) for local continuous storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
Further Recommendations Consider a Wi-Fi Range Extender if you have poor connectivity around the home from your Router location
What’s in the box
  • 1x EZVIZ Full HD Wi-Fi Outdoor Smart Home Security Camera
  • 1x Power Adapter with 7.5 Meters total Power Cable
  • 1x Mounting/Drill Template
  • 1x Screw Kit
  • 1x Waterproof Kit
  • 1x Quick Start Guide
Product Description EZVIZ ezGuard Plus CS-CV310-A0-1B2WFR - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor, indoor - splash-resistant
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Camera Mount Type Surface mount
Dimensions (WxDxH) 7.164 cm x 7.164 cm x 15.044 cm
Weight 326 g
Connectivity Technology Wired, wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 30 frames per second
Motion Detection Yes
Video Modes 1080p
Optical Sensor Type CMOS - 1/2.7"
Minimum Illumination 0.02 lux F2.0 - AGC on , 0 lux - IR
Focal Length Control Fixed focal
Focal Length 2.8 mm
Lens Mounting M12 mount
Lens Iris F/2.2
Interfaces Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage DC 12 V
Features Progressive scanning, saturation control, brightness control, contrast control, image mirror, automatic electronic shutter, Intelligent Motion Detection (IMD), infrared cut filter, Digital Wide Dynamic Range (D-WDR), Wi-Fi Protected Setup (WPS), dual video stream, password protection, built-in siren, 3D Digital Noise Reduction Technology, Black light compensation (BLC), WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker, bit rate control, built-in strobe light
Manufacturer Warranty 1-year warranty
Environmental Parameters (operating) -30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ezviz Full HD Outdoor...
£99.99
