We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The LC3 is an innovative integration of a brightness-adjustable floodlight and a powerful 4MP security camera, which enhances your home safety at all levels - even at night. Doubling as a sleek wall lamp, the LC3 fits into any household to light up dark places with remote smart controls. A security camera at its core, the LC3 features AI-powered person detection, active defense, and two-way communication to effectively watch over outdoor spaces such as patios, hallways, courtyards, and more.
Product Description | EZVIZ LC3 - network surveillance camera |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, two-way audio capability, built-in omni-directional microphone |
Camera Mount Type | Wall mount |
Connectivity Technology | Wireless |
Width | 8.6 cm |
Depth | 12 cm |
Height | 28 cm |
Weight | 1.038 kg |
Camera | |
Type | Colour - Day&Night - fixed - outdoor - dustproof / waterproof |
Digital Video Format | H.264, H.265 |
Max Digital Video Resolution | 2560 x 1440 |
Motion Detection | Yes |
Video Modes | 2K |
Infrared LEDs | Yes |
Infrared Distance | 10 m |
Digital Video Capture Resolution | 2560 x 1440 |
Frame Rate (max) | 30 frames per second |
Flash Memory | 32 GB |
Features | Wide Dynamic Range (WDR), built-in antenna, dual video stream, reset button, password protection, Smartphone Monitoring, cloud recording, watermark, heartbeat, anti-flicker, 3D digital noise reduction (DNR), Person Detection, visual alert, built-in siren (100 dB), lamp brightness control, built-in LED light (700 Lumens) |
Image Sensor | |
Type | 4 MP |
Lens Construction | |
Lens Iris | F/2.3 |
Horizontal Field of View (degree) | 140 |
Vertical Field of View (degree) | 75 |
Diagonal Field of View (degree) | 157 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Miscellaneous | |
Included Accessories | Drill hole template, screws |
Compliant Standards | RoHS, AES-128, WEEE, REACH, IP65, TLS |
Colour | Black |
Power | |
Power Requirements | AC 120/230 V |
Power Device | Power supply - internal AC 110-240 V (50/60 Hz) 30 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 15.6 cm |
Shipping Depth | 23 cm |
Shipping Height | 15.2 cm |
Environmental Parameters | |
Min Operating Temperature | -30 °C |
Max Operating Temperature | 50 °C |
Relative Humidity (operating) | 0 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
