Elegant and versatile, the C6W camera is all the protection you need for a large home. It records in 2K resolution and automatically tracks motion in 4x zoom to make sure nothing escapes the eye.
Product Description | EZVIZ C6W - network surveillance camera | Device Type | Network surveillance camera - pan / tilt | Audio | Yes: built-in speaker, two-way audio capability, built-in microphone | Dimensions (WxDxH) | 9.58 cm x 9.58 cm x 9.06 cm | Weight | 252 g | Connectivity Technology | Wired, wireless | Camera | Colour - Day&Night | Max Resolution | 2560 x 1440 | Motion Detection | Yes | Video Modes | 2K | Optical Sensor Type | PS CMOS - 1/2.7" - 4 MP | Minimum Illumination | 0.5 lux - colour - F2.0 - AGC on , 0 lux - IR | Focal Length Control | Fixed focal | Focal Length | 4 mm | Lens Mounting | M12 mount | Lens Iris | F/2.0 | Panning Range (degree) | 340 | Tilting Range (degree) | 75 | Interfaces | Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Voltage | DC 5 V | Features | Backlight Compensation (BLC), progressive scanning, saturation control, brightness control, contrast control, image mirror, infrared cut filter, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker, 3D digital noise reduction (DNR), smart tracking, self-adaptive shutter, motion detection, Person Detection, Auto-Zoom Tracking | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -10 °C - 45 °C; 0 - 95% (non-condensing) relative humidity |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, two-way audio capability, built-in microphone |
Width | 9.58 cm |
Depth | 9.58 cm |
Height | 9.06 cm |
Weight | 252 g |
Camera | |
Type | Colour - Day&Night - pan / tilt |
Digital Video Format | H.264, H.265 |
Max Digital Video Resolution | 2560 x 1440 |
Video Modes | 2K |
Digital Zoom | 4 |
Infrared LEDs | Yes |
Infrared Distance | 10 m |
Image Sensor | |
Type | 4 MP PS CMOS 1/2.7" |
Lens Construction | |
Type | M12 mount - fixed focal |
Lens Iris | F/2.0 |
Horizontal Field of View (degree) | 83 |
Vertical Field of View (degree) | 57 |
Diagonal Field of View (degree) | 104 |
Panning | |
Tilting | |
Interfaces | |
Network Interface | Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Expansion / Connectivity | |
Ports | LAN - RJ-45 |
Supported Memory Cards | microSD Card |
Miscellaneous | |
Included Accessories | Camera mount base, screw kit, drill hole template |
Compliant Standards | UL, NOM, IC, FCC, RoHS, WEEE, REACH |
Power | |
Power Requirements | DC 5 V |
Power Device | Power adapter - external 8 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight (Shipping) | |
Shipping Width | 12.6 cm |
Shipping Depth | 12.6 cm |
Shipping Height | 16 cm |
Shipping Weight | 513 g |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 45 °C |
Relative Humidity (operating) | 0 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
