Fairphone 3 Protective Case - Black
£34.99
23 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock,
    Used stock also available below
Product codes
We’re on a mission to help your Fairphone 3 last as long as possible! This form-fitting protective case provides extra comfort and durability, while maintaining a sleek design.
The Fairphone 3 Protective Case is slim, lightweight and soft, yet sturdy enough to survive unexpected shocks and drops. Made with 37% biomaterials and non-toxic plastic, it wraps carefully around the edges of your screen, creating an airbag effect for maximum protection. With precise cutouts and responsive button covers, this subtly designed case is purpose-built to help your Fairphone 3 last as long as possible.
Product Description Fairphone 3 - back cover for mobile phone
Product Type Back cover for mobile phone
Material Plastic
Colour Black
Designed For Fairphone 3
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Not used but packaging is creased
Ref: FTP2 042255
£21.25
product
Ref: FTP2 042255
Accessories
Packaging
Functional
Software
Manuals
£21.25
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fairphone 3 Protective...
£34.99
