Fairphone 4 Screen Protector v1 Privacy
£18.00
Select:
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
  • Device Type: Fairphone 4
  • Type: Screen Protector
  • Product Range: Fairphone
  • Product Model: Fairphone 4
Product codes
Screen Protector with Privacy Filter
Our privacy screen protector serves double duty to keep your display in pristine condition while also ensuring that no one can sneak a peek on your screen. Super-spy type stuff.
We're on a mission to help your Fairphone 4 last as long as possible! Our screen protectors are designed to do just that. The 9H tempered glass is highly durable, providing excellent scratch resistance and even protecting against low-level drops. A special surface coating reduces fingerprints, and the curved edges round out the discrete design. Our screen protectors come in two filter-versions (blue light & privacy); both are easy to apply and remove.
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Damaged stock - Item is new but has packaging damage
Ref: GS94 046967
£13.22
product
Ref: GS94 046967
Accessories
Packaging
Functional
Software
Manuals
£13.22
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£18.00
