What can this little charger do? Spoiler alert, it's all in the name. It has two ports, USB-A and USB-C, supports fast-charging technology and reliably charges a broad range of devices
Fairphone designed this versatile dual-port charger to be your go-to solution for quick and efficient power-ups. It’s compatible with a range of electronic devices, like the Fairphone 3(+) and of course the Fairphone 4. And get this, with its 30W power delivery it will jumpstart the battery of your Fairphone 4 to 50% in just 30 minutes. Add to that the 18W USB-A port and you’ve got one very well-rounded charger. And it wouldn’t be a Fairphone charger, if we didn’t do our best to include recycled plastic in its housing
Ports
More Information
Cables not included
Customer return - item has been used and shows signs of use
Ref: GNV7 046580 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£10.68
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
