Fairphone Modular Earphones
£44.98
24 in stock
Delivery:
Standard: 1-3 working days
  • Accessory Type: Headphones
  • Connectivity: Wired
  • Colour: Black
  • Stock Status: In Stock
Product codes
These modular headphones with dual dynamic drivers deliver a high-quality, balanced sound, while the memory foam earbuds provide increased comfort and noise isolation.
Easily skip tracks, change volume or answers phone calls using the built-in remote and microphone. The 45° angled audio plug provides strain relief to prevent the wires from breaking easily.
Fairphone earphones are modular, so if the cable frays over time, you only need to replace the cable. Using gold plated MMCX connectors, it can be replaced within seconds.
Cable length 1.2M
Compatible with Fairphone 3, as well as most Android and Apple devices with a 3.5mm audio port.
Product Description Fairphone Modular Earphones - earphones with mic
Product Type Earphones - wired - 3.5 mm jack
Headphones Form Factor In-ear
Connectivity Technology Wired
Headphones Technology Dynamic
Sound Output Mode Stereo
Controls Volume, answer/end, skip track
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fairphone Modular Earp...
£44.98
