Fellowes Smart Suites Flat Panel Monitor Arm
£36.56
Delivery:
Key features
  • Elevates Flat panel monitors to optimal viewing height with four fixed height positions offering up to 100mm adjustment
  • Vertical tilt adjustment (45 to -45°) and 360° swivel
  • VESA compliant
  • Supports screens up to 9kg and 21"
  • Easy to mount two piece clamp
Product codes
Elevates Flat panel monitors to optimal viewing height with four fixed height positions offering up to 100mm adjustment. Vertical tilt adjustment (45 to -45°) and 360° swivel. VESA compliant. Supports screens up to 9kg and 21". Easy to mount two piece clamp.
Product Description Fellowes Designer Suites Flat Panel Monitor Arm - mounting kit
Product Type Mounting kit
Mounting Components Support arm, desk clamp mount
Dimensions (WxDxH) 12.1 cm x 36.8 cm x 61 cm
Adjustments Tilt
Weight 2 kg
Recommended Use Flat panel
Recommended Display Size 21"
VESA Mounting Interface Yes
Max Load Weight 9.1 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fellowes Smart Suites...
£36.56
