Fellowes Smart Suites Monitor Riser / Monitor Stand
£17.56
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Raises your screen to eye level to prevent neck strain
  • Supports up to a 21” flat panel monitor or a maximum weight of 10kgs
  • Includes three different height positions: 100mm, 115mm & 130mm
  • Accessory Type: [N/A]
  • Stock Status: In Stock
Product codes
Declutter your desktop and raise your monitor to a more comfortable level. Great for maximising desk space, this monitor stand fits neatly into a corner and allows for document storage.
  • Supports up to a 21" flat panel monitor or a maximum weight of 10kgs
Product Description Fellowes Smart Suites Corner Monitor Riser - stand
Product Type Stand
Dimensions (WxDxH) 47 cm x 31.8 cm x 13 cm
Adjustable Height 10-13 cm
Adjustments Height
Weight 712 g
Recommended Use Monitor
Recommended Display Size 21"
Max Load Weight 18.1 kg
Material Acrylonitrile butadiene styrene (ABS)
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fellowes Smart Suites...
£17.56
