Fitbit Charge 3 Fitness Tracker - Black / Graphite Aluminium
FREE DELIVERY
LIMITED TIME OFFER
PRICE DROP
WAS £119!
£95.00
Colours:
46 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • More ways to know & improve yourself
  • A smart way to stay connected
  • Built for the way you move
  • Device Type: Wearable Tech
  • Type: Tracker
  • Stock Status: In Stock, Used Stock
Product codes
Charge 3
Fitbit's most advanced tracker ever
Fitbit Charge 3 helps you know your body and understand your health so you can take action to improve yourself.
24/7 Heart Rate
Goal-Based Exercises
Swimproof
Sleep Tracking & Stages
Smartphone Notifications
Up to 7 Day Battery
Know yourself on a whole new level
Fitbit Charge 3™ reveals insights about your body, your fitness and everything in between–because the better you know yourself, the better you can be.
24/7 Heart Rate
Charge 3 uses our most advanced heart rate sensors and algorithms to uncover meaningful insights on your heart.
All Day Calorie Burn
Know how many calories you’re really burning and use what you learn to reach your goals.
Real-Time Heart Rate Zones
See when you’re in Fat Burn, Cardio or Peak zones to make the most of every workout.
Auto Sleep Tracking
See how long you’re in light, deep and REM sleep and get personalized insights to learn how to get better rest.
Female Health Tracking
Use Fitbit Charge 3 with the Fitbit app to track periods, record symptoms and estimate ovulation and fertility windows.
Fitbit App Dashboard
Set goals, find inspiration, connect with friends and get a snapshot of your health and fitness all in one place.
Get guidance to make moves on your goals
The more you wear Charge 3, the more you learn about yourself and your workouts so you can start making changes that matter.
7 Day Battery
A multi-day battery life keeps insights and inspiration coming day and night. Varies with use and other factors.
Smarter, Sharper Touchscreen
The large, backlit display automatically adjusts to lighting conditions so you can easily see stats any time of day.
Durable, Lightweight Design
With aerospace-grade aluminum, a smooth-flush case and Corning® Gorilla® Glass 3, Charge 3 is comfortable and durable.
Product Description Fitbit Charge 3 - graphite - activity tracker with sport band - black
Product Type Activity tracker
Connectivity Bluetooth
Supported Host Device OS iOS, Android, Windows Phone
Display Monochrome OLED
Tracking Data Distance, time, calories burned, activity, sleep activity, heart rate, steps taken, pace, sleep stages
Band Black - sport band
Features Heart rate sensor, calendar notification, SMS notification, tap control, PurePulse heart rate technology, changeable band, automatic exercise recognition, SmartTrack, inactivity alert
Battery Run Time Up to 7 day(s)
Case Material Aerospace-grade aluminium
Dimensions (WxDxH) 11.8 mm x 28.8 mm
Weight 30 g
Manufacturer Warranty 1-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: DV4P 041432
£69.30
product
Ref: DV4P 041432
Accessories
Packaging
Functional
Software
Manuals
£69.30
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fitbit Charge 3 Fitnes...
£95.00
