Fitbit Charge 4 - Rosewood
FREE DELIVERY
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Built-in GPS
  • Active zone minutes
  • 24/7 heart rate
  • Track workouts
  • Sleep score
  • Get notifications
  • Device Type: Wearable Tech
  • Type: Tracker
  • Stock Status: In Stock,
    Used stock also available below
Product codes
With Fitbit Charge 4, there's no limit to how far you can go. This sleek, swimproof tracker is packed with features that help you know your workouts and your body better. You get more convenience on the go and more inspiration to reach your fitness goals.
24/7 Heart Rate
Use 24/7 heart rate to better track calorie burn, optimise workouts and uncover health trends.
Resting Heart Rate
Record your resting heart rate, track heart rate trends over time and follow your health & fitness progress.
Heart Rate Zones
During workouts, get real-time stats on screen to see whether you’re in Fat Burn, Cardio or Peak zone, so you can dial the effort up or down according to your goals.
Workout Intensity Map
Get a better understanding of your effort during outdoor workouts with a map in the Fitbit app which shows when and how long you were in each heart rate zone.
Active Zone Minutes
See which heart rate zone you’re in to gauge if you’re working hard enough to reach your goals.
Goal-Based Exercises
Go into exercise mode during your favourite workouts to set a goal for each workout and see real-time progress of your effort on screen.
Built-In GPS
During outdoor runs, rides, hikes and more, use built-in GPS to see your pace and distance on Charge 4, then see a map of your workout in the Fitbit app.
Water-Resistant
Designed to be water-resistant to 50M, Fitbit Charge 4 automatically tracks swim workouts and can be worn in the shower, pool and beyond.
Spotify Control
Amp up your workout when you control music, like songs and browse playlists and podcasts from Charge 4.
Guided Breathing Sessions
Take a moment for mindfulness by following an on-screen guided breathing session that’s based on your heart rate.
Notifications & Apps
Stay connected with call, calendar and smartphone app alerts, text notifications and helpful apps like weather and timer. Plus, send quick replies to messages on Android only.
Sleep Stages & Score
Charge 4 tracks your time in light, deep and REM sleep stages and gives you a nightly Sleep Score in the Fitbit app, so you can quickly understand your sleep quality and work toward better rest.
Long Battery Life
With a battery life of up to 7 days—and up to 5 hours when using GPS—Fitbit Charge 4 lets you do more with less charging. Varies with use and other factors.
Fitbit Pay
Load your credit and debit cards to your Wallet in the Fitbit app, then use Charge 4 to tap and pay for purchases on the go—at transit stations, your favourite stores and more. Not available with all transit systems and banks. See availability.
All-Day Activity Tracking
Charge 4 tracks all-day activity like steps, distance, floors climbed, Active Zone Minutes and calories burned to show how every part of your day gets you closer to your goals.
Female Health
Know your body better by using your tracker with the Fitbit app to follow your cycle, record symptoms and more.
Reminders to Move
Keep yourself on track toward your goals with fun, on-screen reminders that encourage you to move throughout the day.
Daily Dashboard
See all your activity stats in one place with a daily dashboard that shows your steps, calories burned, sleep, heart rate and more.
Clock Faces & Accessories
Personalise your Charge 4 by choosing your own clock face and switching out your classic band for accessories in leather, woven, sport styles and more. Accessories sold separately.
Intuitive Touchscreen
Fitbit Charge 4 makes it easier to see your stats in sunlight, at night or anytime, thanks to a large touchscreen and backlit display that adjusts to different lighting conditions.
Wireless Sync
Charge 4 automatically syncs to most popular iOS and Android devices to show your stats, trends and progress on your Fitbit dashboard.
Mobile App
Set goals, track progress and get a more complete picture of your health & fitness—from nutrition and hydration to exercise and sleep—all on your dashboard in the Fitbit app.
Size Guide
Both small and large sizes included in box.
Small - Fits wrist 140 mm - 180 mm in circumference
Large - Fits wrist 180 mm - 220 mm in circumference
Product Description Fitbit Charge 4 - rosewood - activity tracker with band - rosewood
Product Type Activity tracker
Connectivity Bluetooth
Supported Host Device OS iOS, Android
Display Monochrome
Input Touch screen
Navigation GPS receiver
Tracking Data Distance, time, calories burned, activity, sleep activity, heart rate, steps taken, pace, sleep stages
Band Rosewood - band - elastomer - up to 247 mm
Features Heart rate sensor, navigation, calendar notification, SMS notification, LED backlight, social apps notification, inactivity alert, incoming calls notification, applications notification, music playback control, Active Zone Minutes, guided breathing session, heart rate zones, female health
Battery Run Time Up to 7 day(s)
Dimensions (WxDxH) 12.5 mm x 28.8 mm
Weight 30 g
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: FRM1 042467
£88.70
product
Ref: FRM1 042467
Accessories
Packaging
Functional
Software
Manuals
£88.70
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fitbit Charge 4 - Rose...
£129.00
