Get Creative
On the LCD screen you can choose your favourite shots and start editing. There are 10 pre-installed image frames, but there are 30 in total to choose from on the Instax app. By assigning your favourite frames to the camera's shortcut buttons you can add speech bubbles, colour filters, and much more.
Capture Sound
Select Sound Mode to record a sound clip with your snap and convert it to a QR Code. Then simply print & scan it with your smartphone to hear it back and relive the moment.
Remote Control
You can control this clever little Instax camera remotely by connecting to a smartphone via the app and turn that phone into a remote control, helping you make sure everyone, and everything is in shot when you can't reach the camera itself.
Snap And Print
Once you're happy with your photos you can print them instantly on Fujifilm Instant Instax Mini film (available separately). Like the camera itself, the photos will also be mini at 8.6 x 5.4cm, perfectly sized for wallets and pockets. Photos print via the app in less than twenty seconds, and around 100 photos can be printed on a single charge of the camera.
Product Description | Fujifilm Instax Mini LiPlay - digital camera | Product Type | Digital camera - compact with instant photo printer | Memory Card Slot | microSD card | Lens System | Wide-angle lens f/2.0 | Focus Adjustment | Automatic | Min Focus Distance | 10 cm | Display | LCD display - 2.7" | Supported Battery | Li-ion rechargeable battery (included) | Colour | Blush gold | Dimensions (WxDxH) | 12.29 cm x 3.67 cm x 8.25 cm | Weight | 255 g |
General | |
Enclosure Colour | Blush gold |
Optical Sensor Type | CMOS |
Optical Sensor Size | 1/5.0" |
ISO (Max) | 1600 |
Print Standard | Exif Print support |
Image Recording Format | JPEG |
Connectivity Features | Remote control via mobile devices, wireless image printing |
Exposure & White Balance | |
Light Sensitivity | ISO auto (100-1600) |
Exposure Metering | Multi-segment |
Exposure Metering Zones | 256 |
Exposure Modes | Programme, automatic |
Special Effects | Black & White, Sepia, Vivid, fisheye, Poster, Stylish |
White Balance | Automatic |
Max Shutter Speed | 1/8000 sec |
Min Shutter Speed | 1/4 sec |
Exposure Compensation | ±2 EV range, in 1/3 EV steps |
Lens System | |
Type | Wide-angle lens f/2.0 - wide angle |
Focal Length Equivalent to 35mm Camera | 28mm |
Additional Features | |
Additional Features | Audio recording, built-in speaker, USB charging, integrated selfie mirror, QR Code print, Audio QR code encoding |
Display | |
Type | 2.7" LCD display |
Display Format | 230,000 pixels |
Display Form Factor | Built-in |
Microphone | |
Microphone Operation Mode | Mono |
Connections | |
Connector Type | USB (power only) (micro-USB) |
Miscellaneous | |
Included Accessories | USB cable |
Battery | |
Battery Type | Lithium Ion - manufacturer-specific |
Details | Li-ion rechargeable battery (included) |
Memory / Storage | |
Supported Memory Cards | microSD Card, microSDHC Card |
Memory Card Included | No |
Dimensions & Weight | |
Width | 12.29 cm |
Depth | 3.67 cm |
Height | 8.25 cm |
Weight | 255 g |
Weight Details | Camera only: 255 g |
Shipping Dimensions (WxDxH) / Weight | 14.7 cm x 10.3 cm x 8.6 cm / 540 g |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
