Fujitsu B22-8 TS 21.5" 1920x1080 5ms VGA DVI DP LED IPS...
Fujitsu B22-8 TS 21.5" 1920x1080 5ms VGA DVI DP LED IPS Monitor
£136.71
22 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
The B24-8 TS Pro is made for intensive office work. With visual and mechanical ergonomics this stylish display enables fatigue-free working for hours in front of the screen. The large screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
Product Description Fujitsu B22-8 TS Pro - Business Line - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Energy Class Class A+
Energy Consumption per Year 21 kWh
Power Consumption (On mode) 14 W
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 10 ms (typical); 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 50.05 cm x 21.27 cm x 32.255 cm
Weight 4.63 kg
Localisation United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards FCC Class B certified, TUV GS, VCCI, BSMI, cUL, EN 60950, SASO, CCC, DDC/CI, RoHS, WEEE, S Mark, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TCO Displays 7.0, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu B22-8 TS 21.5"...
£136.71
