The Display B22W-7 LED offers best ergonomics and usability for intensive office use with a 4-in-1 stand.
Customers with focus on ergonomics prefer the flexibility of a stand that is totally flexible for individual adjustments. Best-in-class height-adjust, stunning swivel, tilt and rotation to portrait guarantee a healthy, fatigue-free posture during long usage sessions.
Product Description | Fujitsu B22W-7 LED - Business Line - LED monitor - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class A+ | Energy Consumption per Year | 22 kWh | Power Consumption (On mode) | 15 W | Features | USB 2.0 hub | Panel Type | TN | Aspect Ratio | 16:10 | Native Resolution | 1680 x 1050 | Pixel Pitch | 0.282 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Colour | Marble grey | Dimensions (WxDxH) - with stand | 51.4 cm x 19.9 cm x 36.7 cm | Weight | 6 kg | Localisation | United Kingdom | Environmental Standards | TCO Certified Displays 7, ENERGY STAR Qualified | Compliant Standards | FCC Class B certified, TUV GS, VCCI, C-Tick, cUL, EN 60950, SASO, TUV S, CCC, DDC/CI, RoHS, WEEE, KC, Directive 2004/108/EEC, EAC, RCM, ISO 9241-307 Class 1 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 22" |
Built-in Devices | USB 2.0 hub |
Panel Type | TN |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 82 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 170 |
Backlight Technology | LED backlight |
Colour Temperature | 6500K, 7500K |
OSD Languages | Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese |
Features | sRGB colour management, HDCP, ECO button, High Frame Rate Control (Hi-FRC), 24/7 operating mode |
Dimensions (WxDxH) | 51.4 cm x 19.9 cm x 36.7 cm - with stand |
Weight | 6 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1.5 Watt |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , DisplayPort , Audio line-out , Audio line-in , 4 x USB 2.0 downstream , USB 2.0 upstream |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 340 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m |
MTBF | 70,000 hour(s) |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 22 Watt |
Power Consumption Stand by | 0.19 Watt |
Power Consumption Sleep | 0.16 Watt |
Software / System Requirements | |
Included Software | Display View IT Suite |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 51.4 cm - depth: 19.9 cm - height: 36.7 cm - weight: 6 kg , Without stand - width: 51.4 cm - depth: 6.5 cm - height: 34.6 cm - weight: 3.4 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 7.5 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
TCO Certified | TCO Certified Displays 7 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - pick-up and return |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
